Car shop has star diagnosis does not know how to lower car via star
Old Jun 28, 2011 | 09:55 AM
S500 Man's Avatar
White S63 AMG W/Designo Interior
I asked a local certified MB mechanic who has a star computer, if he can lower my car, he said yes but that he does not believe it is possible, can anyone explain how its done in Star???he says i have to go to dealer because they use a diff computer for lowering, but that if i find out how otherwise he will do it.
Old Jun 28, 2011 | 11:27 AM
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
Just go into Chassis/Body and select height. Make adjustments, then allow it to recompensate. Pretty easy really.
The dealer does use a different measuring device for height, but I work with my dealer daily as a supplier, and he said for "non-radical" adjustments, it is not necessary. I adjusted my my 05 CL down about an inch.
classyS's Avatar
2001 S430
i asked the same thing at the first indie dealership i called, he said he didnt know nor it would be safe, so i called a few other shops and they charged in the range of $400-550!! was like daaaaamn, isnt it better to get links???
Old Jun 28, 2011 | 07:13 PM
tusabes's Avatar
Mercedes
If the guy doesn't know how to use Sd then you wouldn't want him adjusting it anyway.
Also Sounds like he doesn't want the liability if you complain
Old Jun 28, 2011 | 11:33 PM
S500 Man's Avatar
This will be the same with a 2008 CLS 550?
Old Jun 28, 2011 | 11:50 PM
B16RacerN2NR's Avatar
06 Pontiac Vibe, 01 Dodge Ram, 01 Honda CBR600
All the values in the SDS must be within factory specs set by MB if you wanna lower your vehicle through the SDS.
I'll try to elaborate more...
Let's say MB set the ride height with the level sensor values @ 3 volts. Let's say half an inch raising or lowering moves the values + or - 1 volt and that's what MB put into the control module/unit as "ok". You can get the vehicle as low as you want but once you confirm that ride height and the SDS doesn't like the values of the ride height level sensors, it'll kick it back and return to the previous settings.
This has happened to me on 221's and 230's though. I know you're asking about a 220 but i'd hate for you to take it to the dealer and spend money only to find out it can't be set to what height you want.
Old Jun 29, 2011 | 01:24 AM
S500 Man's Avatar
no i have a 219 CLS 550! my s500 is retired.
Old Jun 29, 2011 | 08:52 AM
Oh sorry. I just assumed since it's in the 220 section lol.
Old Nov 29, 2011 | 08:54 AM
Sgt. Schultz's Avatar
opposite-lock...
Revisiting this, please indulge me.
Had it on STAR last night, could see all the test / diag features and do them but couldn't for the life of us figure out where to input values to set height adjustment.
Can someone please elaborate? This should be helpful but I'm thick 8-/:
"Just go into Chassis/Body and select height. Make adjustments, then allow it to recompensate. Pretty easy really."
Any insight appreciated - TIA gents... bish needs to come down a bit, esp in front...
Also, his 16pin connector has a missing pin so we were in via the OBDII cord - is that doable for this still or do we need to use the 16pin connector?
Old Nov 29, 2011 | 10:03 AM
Das Geld 2's Avatar
SL55, S500
https://mbworld.org/forums/w211-amg/...ts-o-pics.html
Old Nov 29, 2011 | 02:49 PM
opposite-lock...
Thanks - great thread, but... post #193 in there seems to suggest our 220's require 'something additional'?
Further along the lines of that thread... have many here shaken the secret handshakes that exist with STAR for our heaps / care to share?
