4Matic new wheels / rims 19x8.5 and also 19x9.5 --possible
I would like to put them on my car, but understand that staggered wheels on an S500 4Matic is bad for the drivetrain.
Is it possible to somehow put the right widths on the tires to make them equal? What would that balance be?
Currently on the fronts there are 245/40/19 and on the rears its 275/40/19
Any thoughts? Thanks in advance
Check out this calculator, it will help you out:
http://www.miata.net/garage/tirecalc.html
http://gti-vr6.net/library/engine/Sc...ldiameters.htm
So you can get a staggered wider tire, as long as the diameter of the front and rear is the same
And this would be totally fine for my awd?
Yes you can put the exact same size tire on all four wheels on the wider rear wheels , but it might look stretched.
The right way to do it, as everyone has told you, is to pay attention to DIAMETER of the tire.
A wider tire can have the same diameter as the narrower tire if the aspect ratio is lower. 245 40 19 and 275 40 19 have the same aspect ratio so they will not work, but a 275 35 19 might.
Check on tirerack,com to see the diameter of 245 40 19 and find a comparable wider tire with aspect ratio that matches, or just call them they can explain it to you
