LED plate light DYI
1- Open trunk lid remove the screws around the handle or button (depending if you a auto trunk closer) with a T15 screw driver.
2- Pull the trunk lining down and completely off as it attached with clips, you must also disconnect the emergency button which is released by a simple clip.
3- The are 6 screw that are 10mm that hold the area the plate attaches to the trunk. they are located around the pump by the lock
4- Remove your plate to reveal two more 10mm screws that are on the outside.
5- Use a plastic wedge to pry the part away from the car (one that holds the plate) start at the top as there is 4 clips at the top around the chrome trim area, this should allow the piece to come free.
6- Remove the old lights the squeezing both sides (from the inside around the pump) and pushing them down threw the opening,once out disconnecting the plug that supplies power.
7-Plug new lights in and test.
To finish reassemble in reverse order and enjoy the bright new lights.
Second pic is the screws you need to remove around the plate on the outside
Third pic is the old light vs the new one
Forth pic is the lights on testing if they work, notice how bright they are in bright light
Last is the finished product
but
I've got to ask
why...
...WHY would you want your plate MORE VISIBLE???
8-)
OK, maybe I'm weird (uh, scratch that - I'm weird)... but the less visible / memorable my plate is THE BETTER!
just sayin'
I will however use your writeup to spray a light film of black paint inside my lenses.
Or maybe I'll just sharpy over them as I did my //S8 ones... alot easier and nearly as effective.
but
I've got to ask
why...
8-)
just sayin'
