Change Your Plugs/Wires
Old Jan 13, 2012 | 04:42 PM
Das Geld 2's Avatar
SL55, S500
I guess 100k isn't really the threshold..
Took about a few hours.
The hardest part was getting the wires to snap onto the plugs as it was tight in the rear.
All my idle vibration is gone. The only way I can tell the engine is on is because the cluster is on.
Old Jan 13, 2012 | 04:46 PM
cmpcpro's Avatar
2004 CLK 500
I just did mine the other day at 108k and all the gaps were toast.. They should have been done a long time ago.. didn't replace the wires though, but I guess I am going to, everyone keeps saying how much better it is with new plugs..
Old Jan 13, 2012 | 07:50 PM
Quadcammer's Avatar
96 and 08 911 turbos
to make it easier to get the wires on the plugs, put a dab of dielectric grease on the opening of the wire . It pretty much slides right on at that point.
Old Jan 14, 2012 | 01:45 AM
Das Geld 2's Avatar
SL55, S500
I used silicone spray. Tell me that was safe?
Old Jan 14, 2012 | 08:36 AM
Quadcammer's Avatar
Yeah I wouldn't have done that. As far as I know, silicone spray does not promote the conduction of electricity. It may not cause any problems, but dielectric grease is designed specifically for this kind of situation.
Old Jan 14, 2012 | 09:07 AM
Das Geld 2's Avatar
SL55, S500
Thanks, noted.
I just followed this guide here:
http://www.youtube.com/watch?v=eycUkQ9T1V0
He sprayed it on the wires.
Old Jan 15, 2012 | 10:44 AM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
plug gaps matter
i maintain a powerplant for a drone that has 8 plugs, i can see exhaust gas temp differentials between clyinders with as little as .004 out of tolerance. i am absolutely replacing the plugs in my car when i get back to the states. 43 days to go! so sick of the sandbox. be patient when you gap plugs and try your best to get them all as close as possible.
Old Jan 16, 2012 | 06:05 PM
paultyk's Avatar
2003 S430 4Matic
Did you have check engine light on? Any codes before you replaced them? Or simply vibrations and no other problem.
Old Jan 16, 2012 | 07:21 PM
Das Geld 2's Avatar
SL55, S500
just vibration at idle.
Old Jan 16, 2012 | 07:28 PM
paultyk's Avatar
2003 S430 4Matic
Ok. I have a little vibration but only when on drive when stopped. Idling on park or neutral is fine. No other issues.
Old Jan 16, 2012 | 07:47 PM
Das Geld 2's Avatar
SL55, S500
What's your mileage?
Could be motor mounts, I read some people say trans mount, but why would it cause vibration...
Old Jan 16, 2012 | 07:55 PM
02S430's Avatar
W220 M113K
this is only when stopped correct? not driving
Old Jan 16, 2012 | 07:57 PM
paultyk's Avatar
2003 S430 4Matic
I have 120k. Checked mounts, looked fine not cracked or broken. Only thing possibly the age and rubber is soft. It is 2003. Your sparks did not look bad from the picture. I saw sparks with 100k on them already burned out. I have to print out service record from dealer because my sparks look like new, unless the gap is too big.
paultyk's Avatar
2003 S430 4Matic
Correct only when stopped and on drive.
Old Jan 16, 2012 | 07:59 PM
paultyk's Avatar
2003 S430 4Matic
Even when shifting from drive to reverse is smooth, no bump.
Old Jan 18, 2012 | 01:14 AM
Das Geld 2's Avatar
SL55, S500
You want a true test too see if it's your mounts?
It's dangerous, but it gets the job done. Do it on an empty road or LOT.
A. Start The Car
B. Pop Your Hood and leave it up
C. Get back in your Car with the HOOD UP
D. Put the Car in D and FIRST GEAR
E. FLOOR it for a SPLIT second(jack Rabbit) and watch where the engine goes as your peer through the little gap between your hood and the windshield.
Old Jan 18, 2012 | 03:49 AM
cmpcpro's Avatar
2004 CLK 500
A. Start The Car
An easier way is to just go outside pop the hood and while your foot is on the brake get the car some gas and see if the motor is solid, or trys to come uip out of the compartment.
Old Jan 18, 2012 | 10:09 AM
paultyk's Avatar
2003 S430 4Matic
It actually worked engine popped out!
Old Jan 18, 2012 | 01:47 PM
paultyk's Avatar
2003 S430 4Matic
I talked to the mechanic at the dealership and was told to replace trans mount, even when it looks good rubber deteriorate and lower trans, and then vibrations may appear. It is the cheapest option since no other visual or electrical problems appear.
Old Jan 18, 2012 | 04:00 PM
Das Geld 2's Avatar
SL55, S500
Old Jan 18, 2012 | 04:05 PM
tower's Avatar
2002 s500
Do it in reverse and forward. Engine twists in opposite directions.
