Blower Motor Replacement Procedure
Old Mar 6, 2012 | 06:12 AM
Adrianx's Avatar
2004 S500 4Matic
HI All,
I just purchased 2004 S500 4Matic. I used to own S430 4Matic and loved it to come back to MB.
My Blower Motor is making screeching noise and need replacement. Can someone give me detailed procedure to replace the blower motor?
Thank you.
Old Mar 6, 2012 | 09:56 AM
Quadcammer's Avatar
96 and 08 911 turbos
basically crawl under the passenger side dash, remove the underdash covers with a screw driver, locate blower motor, remove the few screws holding it in, undo the regulator, replace, and reverse to install.
Old Mar 6, 2012 | 03:40 PM
Adrianx's Avatar
2004 S500 4Matic
Thanks. I appreciate it. Sounds easy enough for me to tackle one weekend.
Old Mar 6, 2012 | 03:51 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The diagrams at http://www.mercedestechstore.com/pdf...2010-30-02.pdf (one of which covers the blower motor) might help.
Old Mar 6, 2012 | 08:55 PM
Adrianx's Avatar
2004 S500 4Matic
Thank you
Thank you. I appreciate it.
Old Mar 13, 2012 | 07:28 PM
carllisa's Avatar
2004 S500
Same issue with my 2004 S500 got a quote of 800.00 for just the blower thru dealer.
I hope it will last a while. I think what happened was the drain was clogged under the
hood and water came in thru the glovebox which got the blower wet.
Old Mar 13, 2012 | 07:37 PM
Das Geld 2's Avatar
SL55, S500
Whats your email, I have the instructions in PDF.
Old Mar 13, 2012 | 08:54 PM
carllisa's Avatar
2004 S500
carl.abrahamson@multiplan.com... Thanks..
Old Mar 13, 2012 | 11:12 PM
Das Geld 2's Avatar
SL55, S500
Yep, your fan is seized with rust. simple clean up and it should work!
sent
Old Mar 13, 2012 | 11:16 PM
Viet_Amg408's Avatar
Pinto
make sure the water drain is not clog...
sometimes it just leaves got suck inside the fan blade, it cause the same noise.
Old Mar 15, 2012 | 10:06 PM
carllisa's Avatar
2004 S500
Mine was clogged with just sand.. If I hadn't known to check it from this site I would have thought it was normal.. Really had to look at it with a bright light.
I've had the car 3 months and do love it.. I had to drive a new S550 4matic "1200 miles" from florida a few weeks ago and that car was very nice but I didn't mind going back to mine at all. Didn't like the tiny auto shifter on the new car though..
Old Jan 28, 2013 | 10:13 AM
hooligan's Avatar
E500 2004
can you please sHare the pdf with me as well?
Jeeperak@GMAIL.COM
Old Feb 16, 2013 | 08:16 PM
ThierryRemy's Avatar
s430
Jeeperak@GMAIL.COM
same here
I will pm you my email
Old Feb 17, 2013 | 09:24 AM
wallyp's Avatar
2003 S500 2007 GL450
A blower motor which is squealing, but still works, can usually be saved by simple cleaning and lubricating. I am old enough that I enjoy fixing something, rather than replacing it. The money saved is a bonus...
Old May 18, 2013 | 12:17 AM
bigharp1's Avatar
2001 S500
Blower Motor Replacement Diagram(s)
Das Geld 2,
Would you also send me the diagram for replacing the blower motor and/or other related components?
Thanks,
BigHarp
Old May 20, 2013 | 07:44 PM
Das Geld 2's Avatar
SL55, S500
Here
Old May 21, 2013 | 10:40 PM
bigharp1's Avatar
2001 S500
Thanks, Das Geld2,
Straightforward and to the point.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
