How much has she costed you?
Any way, she added 15k miles within a year.
On my S600, I spent about $2500 after acquired it to make it a daily driver: Eurocharged tunes, tandem pump, radiator, lower struts, plugs and filters, auto trunk operation,...
It's still have random #7 misfire on idle mode that I haven't able to eliminate. I can avoid #7 misfire by listening to the way it starts: if hesitation on start then shut it off and restart.
I'm stubborn and haven't take it in for a diagnostic yet.
Attachment 358277Attachment 358276
I replaced the fuel pump and fuel filter but not the controller as I have the latest 5bar unit.
The misfire intensified when I replaced the dirty K&N engine filter for OEM filter which is strange...
Add $250 and 5 hrs for a new radiator.
:/ Still, a German luxo panzer for less than 4% of MSRP.
If I am going to do it again I would go with OEM.
Before doing anything, inspect the new radiator and make sure it’s to spec; this is really important.
- Make sure the outside diameter of the hose receptacle is 41.0 to 41.5 mm.
- Make sure you have threaded receptacles for the fan cowl, IC HE, IC pump, AC HE and AC pipe fittings.
- When you remove the old radiator, some of those fittings may be rusted up – test them first, and figure out what you’re going to do.
- There are rubber & plastic mouldings all around the radiator to control airflow, and they take time to remove & refit.
- Establish whether your header tank fills to the RH header tank, or the bottom hose.
- The new radiator may have a ¾” filler hose receptacle that may need to be blocked off – which can make fitting more difficult.
- Lift the front end of the car onto stands and remove the top and bottom covers.
- Loosen the header tank cap and drain the cooling system. This takes a while.
- Remove the thermostat/top hose housing and disconnect all the hoses (expect spills).
- Disconnect the electric fan.
- Remove the small clips that hold the top of the fan cowl to the radiator flange.
- Remove the two clips that hold the bottom of the fan cowl to the radiator flange.
- Undo the two transmission oil cooler pipes (top one first!), catch a bit of oil, and cover the pipe ends.
- Undo the two nuts at the top corners of the fan cowl.
- Pull the fan assy up an inch, tilt it back and pull it out upwards (pushing the IC pipes out of the way).
- From underneath, undo the IC pump and its bracket from the radiator.
- Still underneath, remove the bolt that holds the aircon pipes bracket to the radiator.
- Unbolt the top L&R of the aircon condenser from the radiator.
- Unbolt the IC heat exchanger from the radiator, and support it.
- Undo the plastic clamps that hold the top of the radiator.
- Push the top of the radiator back and remove the bleed pipe.
- Remove the plastic brackets that are clipped half-way up each side of the radiator.
- Lift the radiator out.
Now is the time to replace the anti-freeze, the thermostat, the thermostat housing o-ring, the hose connector o-rings, and the hoses and aux drive belt if you feel like it.
Refitting is the reverse of removal, but:
- Check that the top hose assy fits both radiator receptacles before fitting the radiator (ask me why).
- Tape sheets of corrugated card to the front and rear faces of the new radiator, otherwise you’ll make a horrible mess during fitting.
- Make sure the aircon condenser is in about the right position before you push the new radiator forwards into position.
- Imperative to make sure all the small hoses and cables are tied away from the moving parts, like the fan, the ancillaries and the aux belt.
- The cooling system bleeds itself, but only when the engine is fully warmed-up, and you need patience.
It took me ages to figure out what was going on, and more time to put it right. I thought I was just being weak, being unable to re-fit the quick-fit connectors. I wouldn't want it to happen to anyone else.
Nick
I had remove the radiator, return it, and get another one.
Nick
My S600 had all of its repairs done at the selling dealer for the first 21 months, then I switched to a local foreign car repair shop that has an excellent reputation.
The problems that left me stranded were always electrical/electronic. I documented all of this in a 24-page letter on June 20 to Mr. Exler in Atlanta. I have not had any response to date. Here are a few excerpts of some of my frustrations from the history of this car:
March 27, 2015 22:30 Dash module quits operating on I-465 by Indianapolis.
March 28 and 29, 2015 S600 quits a few times in traffic. Always starts right up. Trunk would not always open or close with fob or buttons.
March 30, 2015 13:30 Carlton Motorcars, Inc. in Greenville, SC. Checked dash module, found out it had a ten-year extended warranty that expired in February. This 2006 automobile was put into service in February, 2005.
May 26, 2015 18:04 S600 dies at traffic light in inside lane during heavy traffic at North Knoxville Avenue and Byrd Lane in Peoria. Will not start for 45 minutes.
May 26, 2015 20:30 Radio starts coming on and going off by itself while car is parked.
March 14, 2016 20:20 S600 will not start at Washington Walmart for ten minutes.
20:35 S600 dies at traffic light at U.S. Route 24 and Washington Blacktop. Will not start for 50 minutes.
April 18, 2016 15:00 S600 to Sullivan-Parkhill (dealer).
April 26, 2016 23:40 Pick up S600 at Sullivan-Parkhill. They were unable to duplicate the failures. No charge.
August 27, 2016 18:15 S600 dies in traffic. Starts right up.
19:35 S600 dies again. Won’t start for 45 minutes.
September 3, 2016 8:30 S600 will not start at the end of the car wash conveyor in Richmond, Indiana. Fortunately I was able to coast into the street to get out of the way of car behind me. Finally starts around 9:10 after explaining to the local police why it was sitting in the middle of their road.
September 9, 2016 11:10 S600 will not start after a short stop at the Secretary of State’s Office.
October 31, 2016 12:30 The “Possessed S600” is dropped off at Kauth & Mayeur. I complain about stalling when anyone sits in the front passenger seat, the cooling fan may not be operating correctly, the check engine light is on again, and drips on the garage floor again.
November 16, 2016 8:15 Pick up S600 at Kauth & Mayeur. A bad pin had been found in a wiring harness going from the back of the car along the passenger side. When the right conditions were present, a person sitting in the passenger seat would move the harness, causing the pin to short out and the engine to stop. This was repeatable until the connection was repaired.
January 1, 2017 8:30 S600 dies west of Delphi, Indiana on U.S. 421. 20 degrees. Doesn’t start for an hour. Brrrrrrrrrrrrrr.
This is just a small part of the list of events with this automobile. They are running out of components to replace. The only repair that has lasted was to the faulty connector on the passenger side near the front seat.
=marktan;5148765]My wife would say "WAY Too much!"
For perspective: 90k miles on the clock now.
However, in the last 12 months my S600 has had the following:
REPAIRS:
Tire TPMS sensors w/ installation: $350
Idler pulleys (2), tensioner assembly, drive belt, w/ install @ indy mech: $600
24 spark plugs (self installed): $250
2 ignition coil packs (self installed): $2200
Coolant, manifold pressure (4), and air temp sensors: $400
Replaced AC pushbutton Panel: $450
Replaced Duo Valve assembly: $300
Replaced Fan Relay: $250
Replaced Blower motor: $200
MAINTAINANCE:
Air filters: $80
Fuel Filter w/ install: $140
4 Rear tires: $900
About to take it in for new brakes on all 4 corners: $$$$
4 Oil changes $ 600
I know I'm missing things, but that's it in a nutshell...not to mention the HOURS spent under the hood on my own trying to diagnose and DIY.
The big woes - mostly PSE pump (and still a problem since I bought); ABC rear. Everything else is minor but adds up like electronics, a/c compressor, small marker bulbs to both headlight issues.
now 174k miles, only the TPS was replaced (3) times,
first two times within a week, then I realized, Auto Zone and O'Really's quality (for TPS) is less than. Installed myself X3, part 70.00. Oil change every 3k miles Mobil 1 0/40. I'm sick like that. Wipers/brakes/wheels don't count so I won't mention.
I did sit in the drivers seat with a screw driver in my back pocket, seat lost, purchased 02 S600 for seat, 1,700, sold everything else in eBay +4600.00, and still selling. May need to replace accumulator. Total cost, just time really, all things considered, I can only complain about the cost of fuel.
how many miles did it have in 2013?
18-Jul-13, 241,612 miles: Air conditioner compressor $1,462
21-Feb-14, 253,492: Rear flex disc $329, transmission connector $230
4-Aug-14, 261,026: A/C duo valve $736, motor mounts $1,327
1-May-15, 274,104: Ignition $1,560, engine $13870
7-May-15, 274,434: Trans speed sensor $350, front seat switch $330
22-Jun-15, 277,622: Door lock $146, purge valve $454
14-Mar-16, 288,308: Transmission $6,616, left inner tie rod $140
30-Aug-16: Tightener pulley $139
11-Jul-17, 308,516: Transverse control arm $800, headlamp $791, axle boot $664
18-Feb-18, 316,612: Side mirror repair $226, heater valve $498
1-Jun-18, 324,000: Air struts and compressor $8,000, trunk latch $950, tie rod $500, A/C valve $800
Total $41k
Please don't click on any hyperlinks. I don't know why the editing function inserts them. I try to delete them, but they keep linking to eBay ads. ugh.
Starting to see the light at the end of the tunnel.
Have spent $8,200 in parts so far
Oil Filter 275-180-00-09 15
Air Filter Set 275-094-02-04 x2 51
Cabin Filter 210-830-10-18 34
Carbon Filter 210-830-11-18 52
Spark Plugs x24 235
Oil Drain Gasket 007603014106 x1 2
Belt 014-997-37-92 26
PSE Pump 220-800-12-48-64 200
Power Steering Filter 002-184-55-01 7
Transmission Filter 140-277-00-95 11
Transmission Gasket 140-271-00-80 12
Transmission Drain Gasket 140-271-00-60 2
Transmission Filler Lock 1409910055 2
Torque Converter Drain Gasket 007603 010100 x1 2
Fuel Filter 002-477-61-01 37
ABC Dip Stick 2203200259 16
ABC Fluid Filter "0031846101" x2 32
Multi-contour seat control 2158207210 40
Front Engine Cover 2750100367 54
Trunk Lock Actuator 220-750-01-85 269
Front Left Lock 220-720-69-35 455
Front Right Lock 220-720-72-35 455
Rear Left Lock 220-730-71-35 385
Rear Right Lock 220-730-72-35 385
Door Panel Clip 011-988-76-78 x10 20
Front Brake Pad Set 004-420-08-20-41 77
Wear Indicator 211-540-17-17 x3 6
Rear Brake Pad Set 003-420-62-20-41 67
ABC Rebuild Kit x2 120
CHF11 Fluid 15 L 210
Valve Cover Gasket Left 137-016-02-21 26
Valve Cover Gasket Right 137-016-03-21 26
Valve Cover Bolt 002-990-08-03 x28 14
Rear Arm Rest Trim 220-973-00-89 22
Diverter Valve 2750100291 70
diveter valve seal 2759970346 12
Bleed Hose 2750100682 33
Hose 2750100582 33
Hose Connector 1109901178 3
Hood Shock 220-880-03-29 x2 82
Shifter Cover Repair 21
Rear Center Control Piece 220-680-02-07-9C05 54
vacuum lines 42
Splash Shield Bolts / Screws 000000-001410 x2 3
Tires Michelin Pilot Supersport 1100
Right Mirror Signal 220-820-06-21 45
ABC Pump 003-466-52-01 380
Damper Line 220-320-57-72 375
Hydraulic O-ring 028-997-65-48 x3 3
Front left or rear nitrogen accumulator 220-327-01-15 x2 390
Center nitrogen accumulator 220-320-04-15 185
Buffer 6039880511 x2 20
Turbo Tube Seal 0279979948 x2 7
Insulating Tube 40621006200x6 10
Hose 0269975982 x5 22
8mm clamp 0049973090 x10 25
9mm clamp 0079970890 x5 8
10mm clamp 6389971590 x2 5
Air Box Seal 2750940180 8
Pipe socket to thermostat housing seal 6069971045 2
Thermostat seal 1372030180 3
Theromstat Hose seal 269971748 2
Thermostat to water pump hose 1372030082 6
Hose - low temp cooler and charged air cooler 2205013882 44
hose - low temp cooler and water pump 2205013682 13
hose - water pump and charged air cooler 2205013782 28
intercooler filler cap 1245000406 11
ABC Tank to Pump Hose 2209970952 35
Lower radiator hose 2205014882 65
Upper radiator hose 2205015482 27
Breather hose 2205011025 21
Radiator 220-500-20-03 222
IC Pump to Radiator Hose 2205013682 13
Water Pump 275-200-01-01-80 225
Expansion Tank 220-500-00-49 42
Water Pump Gasket 137-201-00-80 5
Lower Radiator Insulator 220-504-00-12 x2 12
Gas accumulator (on relief valve) 220-327-02-15 138
Engine Mount 2202400917 x2 172
Center Shield 2205246330 107
turbo diverter valve 2750960102 x2 64
fuel Hose clamp 6389971590 x2 5
fuel hose clamp 0079970890 x2 4
Seal between crankcase and turbo line 0289977748 x2 5
seal between turbo and oil line to crankcase 2791870180 x2 6
seal between turbo and line to crankcase 2791870080 x2 5
seal between turbo and coolant lines 0289977948 x4 12
ABC line to pulsation damper 2203200454 82
ABC line from pulsation damper 2203200753 71
Transmission Mount 2202400218 53
Transmission bell housing covers 1632710080 x2 5
Harmonic Balancer 2750300003 385
Bolt 69907004 10
Seal 239978447 12
AC O ring 2209970245 x2 4
So far I've spent $1,145 on the following:
Upper Radiator Hose
Radiator Brackets
Fan Assembly
K&N Air Filters
Spark Plugs
Windshield Wipers
Hood Latch Spring
10L Pentosin
2 Accumulators
Fuel Filter
ABC Filter
Then, about a year and a half ago I began to experience an occasional "clunk" when I entered the driveway. Took it in for a look and it was really bad news. The car needed upper and lower control arms on both sides replaced! Their estimate - $3822.00!. Holy Crap! That was approximately half what the car was worth. Could I even sell it? Then it occurred to me that had I replaced the lower control arm when I first purchased the car I probably wouldn't have a problem now. My bad. Since I felt I got burnt on the air strut and driveshaft issues I decided to get a second opinion. Result, second place estimated $2900 but also suggested that I bring it in for an inspection. Their diagnosis was that only three of the control arms needed replacing (one was bad, two others had slight play) so it would only cost me $2030 (they gave me a 10% discount because I'm so good looking!). That's a savings of $1800!!!!! (Hint - Always get a second opinion!)
Turns out that I also needed the air strut pump replaced so they did that - $530. I don't drive the car that much so by some standards it's been quite expensive to maintain but it's still in immaculate condition and it's sell-able which I probably will do sometime next year (and look for a newer S500). And frankly if I had done the control arm back in 2009 PLUS gotten second opinions on all the major work I probably would have saved three or four thousand.
