My car will not start
Old Jun 4, 2012 | 07:12 PM
Sandie Newsome's Avatar
mercedes s430
I own a mercedes 2000 s430. I have changed the fuel filter and pump. It will only run for about 15 minutes then go dead.. It will not start again until I let it sit for a while. It turns over fine. So I know it is getting fire. It is not:smash getting fuel. I am having trouble with my alarm system. Could my alarm system be a reason the fuel stops flowing to prevent it from being stolen.
Old Jun 4, 2012 | 08:28 PM
Quadcammer's Avatar
96 and 08 911 turbos
you sure you put the fuel filter in the correct direction?
Old Jun 4, 2012 | 08:52 PM
mercedes s430
my car will not start
Yes the fuel filter will only go on one way.. I did not take off the old one until I had the new one also.
Old Jun 4, 2012 | 11:09 PM
trombone's Avatar
2002 S430
Cranking Positon Sensor?? Sounds a bit like a CPS problem. Do a little research on the forum on CPS postings. Will find a lot of information including pictures how to change it. Easy DIY fix
Old Jun 5, 2012 | 02:20 AM
tusabes's Avatar
Mercedes
did this problem only happen after you changed the pump and filter, or was the problem there before you changed these parts?
I can almost guarantee you its the CPS. Its a very common failure item and the symptoms are exactly as you describe them, i had the same thing happen to me.
heres the related threads and a video how to change it
Old Jun 5, 2012 | 04:35 AM
tower's Avatar
2002 s500
+1
Do the basics though first. An engine needs compression, fuel and ignition. When the car dies, is there a spark on the spark plugs. No spark, probably CPS. Is there fuel pressure on the rail? No fuel, you did something wrong on the filter change (or something has failed / is failing on the fuel delivery systems).
Old Jun 5, 2012 | 09:40 AM
mercedes s430
Thanks for the help.. I have started my car waiting for it to shut off.. I will check to see if it is getting fire again after that... I did watch the video and it sounds just like mine after it goes dead.
Old Jun 5, 2012 | 01:08 PM
mercedes s430
Thanks to everyone who helped me with my car..It was the CPS.. We replaced it and my car seems to be running fine now.. Again thank you.
I would like to ask if anyone knows about the alarm system.. When I set mine it will suddenly go off all the time.. It will not stop I have to crank my car to get it to stop.. It started doing it about 3 months ago.
