2001 s430 airmatic problem,front sitting low and small cracks on strut tops
Old Feb 11, 2013 | 03:19 PM
kingtheching's Avatar
2001 S430
I have an s430 which i bought a few months back.I didnt winter drive it minus 2 times, the last of which i got an error of car too low dont drive, so i immediately stopped and used the raise button to elevate the car which was enough to keep it up while i drove below 70 km/h home.When i parked the car it was fine but in the morning it was lower on the front end on both sides.when i started it,it raised back up.I asked my mechanic who specializes in mercedes what the problem was and he said it was due to the cold weather.I have read alot on the starter's page and was wondering could the cracks on the top of the struts have caused the problem?here's some pics....the first two are front left, and the last one is front right top
Attached Thumbnails 2001 s430 airmatic problem,front sitting low and small cracks on strut tops-front-left-far.jpg   2001 s430 airmatic problem,front sitting low and small cracks on strut tops-front-left-close.jpg   2001 s430 airmatic problem,front sitting low and small cracks on strut tops-front-right.jpg
Old Feb 14, 2013 | 05:59 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Start your search by using the "w220 owners start here" sticky at the top of the forum start page. The encyclopedia will answer a lot of your questions.
Here is a repair procedure from the other forum;
http://www.benzworld.org/forums/w220...ml#post4255094
YouTube also has information you can search out.
Old Feb 16, 2013 | 12:39 AM
2001 S430
yes i have tried the starters forum,but my question specifically was are those cracks big enough to be problematic?
Old Feb 16, 2013 | 04:01 AM
tusabes's Avatar
Mercedes
Yes
Old Feb 17, 2013 | 02:13 AM
2001 S430
The car doesn't normally sit down,in this case i think it was the cold as prior months there was no problem at all.I hear no leak either,should i get the tops changed in for new ones or should i wait it out?
Old Feb 17, 2013 | 09:34 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Mechanical issues never "heal" themselves and go away. The fact that your front suspension went down at all means you have a problem albeit intermittent. My advice and I'm sure others would agree,is to do the repair sooner than later.
My understanding is that you can do the repair with an available kit or I have read where others have just simply used epoxy to seal the existing cracks with good results. My advise is to read all the Airmatic posts on this forum as well as Benzworld and you will find the solutions to your problem.
I am of the mind that we could have a forum just on "Airmatic" because it seems that everyone experiences issues with that system sooner or later.
Old Feb 17, 2013 | 06:37 PM
2001 S430
thanks for the response,ill probably look into epoxy for now as the kit will be around 500.Any kit you recommend which will last longer as they're born to fail?
Old Feb 17, 2013 | 10:10 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
The epoxy fix should get you through until which time you decide to go with the forum approved Arnott Struts.
Here is a link from the "sticky Start Here" at the beginning of the posts to get you started;
Old Feb 27, 2013 | 08:25 AM
2001 S430
thanks for the reply.gonna look into replacing the tops in the summer most likely
