How can u put car in neutral broken key
Do not do it.
The dealer can supply you a new key without needing your car , they just need the vin number and proof of ownership .
Take your registration papers to the dealer , have a new key made , then you can drive the car. Hopefully you can leave it parked where it is till you can get the new key
Do not do it.
Rich from Benzworks specifically states using this method when you have no power ?
If the plastic locking piece is damaged or broken using this method then I feel the video is misleading by not stating this.
Until the content of the video can be validated as being safe to do without causing shifter or component damage I feel I have done the right thing removing it from the site.
Thank you for putting us right on this one Tusabes.
Do NOT bang on the shifter to get it out of park. That will only break the already-fragile shifter in these cars!
Two options
1. (easiest) Use metal key to open door, get registration out of the car and take it to an MB dealer. They'll have you a key in a few days. I believe they can overnight them in emergencies like yours.. depends on the dealer. All keys come from Texas and I believe they make them same day. You'll need registration, 2 pieces of ID, and you'll have to sign a form for TRP (theft relevant parts) both when you order the key AND when you pick it up. Some dealers have a stupid rule where they need to see the actual car.. call around and find a dealer that doesn't require this otherwise you'll have to tow it....
2. (harder) have the tow truck/flatbed use dolly wheels to raise the rear wheels, then they can pull it onto the flatbed just fine. They do this all the time.. guess how they tow illegally parked cars which are in "park"? Same way! Last time I checked locally, they charged about $30-50 more for hooking up the dollies.. some include it in their price and some charge it as a separate fee.. ask when you call. I think AAA requires them to include it in the basic hookup charge "if required".
So either tow the car there or just go order a key. Don't touch the car otherwise and don't mess with the shifter.
