S600 F1 Exhaust - Making it Happen
I mean seriously. You people are clueless. Yet most of you seem to have one parked in your driveways so im not sure whats going on.
If you cant get that there is a massive, MASSIVE difference in space available between the two then yeah???
We are talking about reproducing what has already been fabricated in a tight engine bay with Mr. Sasaki's headers.
If it has already been done and fitted inside a tight space like that, then it's definitely possible and all you need to do is replicate it. Sure, when we start talking about cost and who could actually do it is a different story.
How many pieces of stainless tube have you ever tacked together in your life with a tig torch in a blind space with 5 other tubes going around it????
Most people cant even tack together a piece of stainless on a bloody bench with any sort of quality within 3months of welding school or actually doing an apprenticeship.
Again im a welder with 25 years of experience. I know what im looking at so dont try to tell me oh its easy we can do this **** in 20 hours with a blindfold on.
I mean FFS you deliver the car to said fabricator....
OH there goes a couple of hrs to 4 just pulling the old headers off and thats if its easy
There goes another hr removing **** that you know is simply going to **** you off.
There goes another hr just sitting there nutting it out....
Lets order some quality stainless steel.... there goes $2000NZD bucks in materials.... Thats actually what v8 materials usually cost and just for the header to mid 304 dairy grade mad in New Zealand stainless steel
Do you know what radius bends he used in the pics? (tighter the radius the more they cost especially in seemless)
How do you cut and fabricate a 6 into 1 collector?
Not something everyone does every day....
Lets spend 15-20hrs just cutting and fabricating two collectors....
What angles to rotate the tube to on each cut?
Will it fit in your bandsaw?
Oh you need a jig to hold the stainless to cut it on that angle in your bandsaw??
Lets spend another couple hrs making jigs just to cut **** on special angles so it all fits up nice as it should....
Oh you finally got it tacked up all the way down the car after 70+hrs....
Lets use whole full size bottle of argon to weld this flash stainless exhaust system up there goes $400+ NZD (argon might be cheaper in the USA)
ETC
ETC
ETC...
Bloody retards.
I did look at your Facebook and your work is impressive
https://m.facebook.com/AMGGTIR/photos
but please try to be civil in the discussion without name calling , thank you !
Exhaust
calling .
Just an update in case anyone was still following this. So, I've decided to purchase the headers from Brilliant Exhaust. I've contacted Mr. Sasaki and just waiting to hear back from him. He stated in his FB post that he's pretty busy and got work cut out for him and was not taking on any new projects. I'm hoping he can fit this in.
I spoke to him before and he gave me a good deal to buy just the headers and ship them to the states. I hope he can still honor that. We'll see.
In the meanwhile, for those who are interested in making a set, I've stumbled upon a company called 'ICENGINEWORKS' and their custom header kits. They are plastic lego-like pieces to mock-up header design. And they include cutting spacers to help you determine the angle of cuts for the piping. This kit makes it really convenient to design equal-length headers and extreme bends on the tubing for those who have a bit more technical know-how on fabricating exhaust. I unfortunately don't have all the know-how to to cut and weld exhaust pipes. Else I woulda given this a try. But if anyone else wants to pursue, then this might be a great option. Here is a link to the product: https://www.icengineworks.com/produc...1500np-series/
Here are some videos which demonstrate how it works:
https://mbworld.org/forums/s-class-w...w220-s600.html
Are you going to modify the headers to clear the shaft? Seems pretty gut-wrenching to cut them up and modify them considering their price tag.
Stressing either an M120 (like I own) or a M137 to 6,000 rpm will get you half way there.
The higher screaming pitch of an F1 V12 is only possible due to the extreme rpm they spin. The exhaust note of a V12 at 6000 rpm will, at best, sound like an F1 engine at half speed. You will not get that famous scream.
It all comes down to Hz, & a V12 puts out 300% the exhaust pulses @ the same RPM as a 4 cylinder, so they generated a lot more Hz of tonal capacity.
The Hz generation of a 4 cylinder at 12K RPM is similar to the Hz generation of a V12 @ 4K RPM
The single greatest contributor from my experience is equal lengths of header tubing before collectors in the proximity of 17 inches. you see a LOT of headers on shrill sounding engines in the 17-17.5 inch range.
So yeah, very close to it being finished, but not yet.
im wondering if my assumption is that it is around 17” to 17.5”
I bought an ICEengineWorks tubular header mock-up kit.
now that my S65 is all good, I figure it’s time to start playing with the M137 S600.
I’m just wondering if my ballpark guess is correct.
also, I might just design a billet collector, so I can accommodate for the steering shaft interference.
I’ll order up some flanges& a 6-1 collector.
I think with the ICEngineWorks kit, I could mock something up quickly.
Short story: So as of now, Headers installed properly. Full straight-pipe exhaust bolted on. Car is running on 6cyl. So it sounds like crap. Trying to get that fixed.
Long story: After I obtained the headers(2020), I was looking for a shop to install them. Since I didn't know any reputable shops besides RennTech which came to my mind, I passed them on cuz I thought they'd charge me arm and a leg and wouldn't be worth it if it costed the same as taking this car to Japan. I searched on Facebook for a shop around Florida since it'd be nice to do some rolling shots and videos after the car was done. Anyways, found a indy benz shop in FL that posted custom exhaust work done on M113 & M156 engines, exhaust fabbing and welding. So I thought, he might be good. This was just after Covid lockdown. Shipped the car with headers to FL. He ended up taking almost 2 years to finish. I didn't know what to do. I subtly pressured him. He said it'd be Summer '21. Then eventually October '21, I finally had the car shipped back. Off the transporter, it was misfiring and shutting down. I said, forget him. I'm not sending it back to him again. Then I decided to send to shops more well known. Decided Eurocharged Houston. Transported the car on Dec '21. They laughed when I told him the previous guy who had the car for almost 2 years. They said tops 4 months. It's almost a year now. And this is where it's at. I dunno what you guys would do if you give it to a shop and they take their sweet time. I was trying to avoid taking to diff shops and wasting money on transporting the car every time. But yeah, I should have either gone to RENNTech first or maybe other reputable shop that I'm sure many of you know. I just didn't. Anyways, I've pretty much lost interest in this. There is only so much one can wait to have something done. I'm gonna try to finish this, take some videos and pics, then sell it and move on. Thanks to all who helped me throughout this project. I don't have the same energy and zeal anymore for this. I've lost countless days of sleep trying to figure out what to do and where to go and how to proceed. But I'm over that now. If these guy at Eurocharged can't figure it out, I'll just offer it for sale as it if anyone wants to take over. I had hopes to make a YouTube channel and make many videos of this car. But I never had the car in my possession for the last 4 years, so I couldn't make any vids. Have 3 kids now since then. So other priorities have taken over. Anyways, will post update when I get something worthy of posting. Still a die hard W220 fan. I know i'll pick up a W215 CL600 later in life for sure.
Wish this had turned out better. Really looked forward to seeing this completed and on the road. Hope it's all wrapped up soon so you can be done with the stress.
On the bright side, if it exists. I got a lot of stuffs planned all these years that I'd do to the car. As the car sits, it's body is a bit unique. Complete W215 front end conversion. I just bought a wald black bison rear bumper with diffuser. I've sourced a Prior Design w215 front bumper & chin spoiler that I'll be putting in. I've got 3 sets of multi-piece wheels plus original Lorinser RS8 wheels. I planned on doing some video shoots with them. So I'm still looking forward to those. And of course bunch of tunnel runs. I also wanted to take it on a closed circuit race track and do high speed runs with it and turn that into some videography. But let's see. Hopefully I reach that point. Thanks for your words of support. Till next update.
