M275 oil in turbo
Old Nov 10, 2016 | 07:04 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
M275 oil in turbo
I searched and found nothing on this subject so here it goes. There are S ome oil in the driver side turbo. The passenger side is dry. What would caused the oil to be on one side and not the other? Is it a real concern?
What is the best way to clean off the oil to see if it would return?
Old Nov 10, 2016 | 08:35 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Isn't the PCV system full pressure line routed into the driver's side intake? So, that side would have a bit of oil residue, while the other side shouldn't...
Old Nov 10, 2016 | 09:02 PM
ItalianJoe1's Avatar
2003 CL 600
Turbo? Or intercooler?
It's not uncommon for older turbos to leak slightly past the seals, a little oil in the system is no reason to panic.
Best way to clean is remove and flush with a brake cleaner or something that leaves no residue, and see if it fills back up. It won't hurt anything to have that little bit of oil in there though.
Old Nov 10, 2016 | 09:27 PM
DrDoe's Avatar
I mean the intercooler. The car had issues with oil in the coolant system in the past and it looks to be free of oil in the coolant hoses this time. More oils are found in the marked area and I guess the oils come from there.
Is that amount of oil normal? I'm trying to figure out if it's the culprit for my P0307 error.
Old Nov 10, 2016 | 10:13 PM
2003 CL 600
307 is a misfire. Odds are you have an ignition issue as they are fairly common on this engine.
A little oil won't hurt and that little bit shouldn't cause a misfire, and almost certainly not on a front cyl, as the TB is on the back of the manifold and would have to be pretty strange to direct any oil going through it all the way to the front of the intake manifold and only one cylinder.
How recent are your spark plugs? Ever done coils or ICM?
Old Nov 10, 2016 | 10:57 PM
DrDoe's Avatar
The plugs on mine are old. I didn't think about them as the previous owner paid for the NGK plugs 5k miles ago.
I opened them up last week and found the Bosch so looked like I got ripped off. Anyway, I am replacing them now and I just noticed the plug on #7/#8 are wetter than other ones.
Old Nov 10, 2016 | 11:03 PM
DrDoe's Avatar
Thank you for the inputs on this. I don't know much about turbo and I was afraid it's something major. So glad that it's not.
Old Nov 11, 2016 | 09:28 AM
Welwynnick's Avatar
2006 S600
MB documents actually advise that its normal to see a bit of oil in and around the LHS turbo, due to the crankcase breathing. Nothing to worry about.
Nick
Old Nov 11, 2016 | 10:16 AM
DrDoe's Avatar
Nick
Good to know. Thank you.
Old Nov 12, 2016 | 09:20 PM
DrDoe's Avatar
I replaced all plugs. Had some fun with them but #7 misfire still there if I leave the engine in idle mode for more than 3min. Also it drives like a C class after the plug works.
#7 & #8 old plugs were wet with oil. What else should I try?
Old Nov 13, 2016 | 04:53 AM
Welwynnick's Avatar
2006 S600
Sounds like there's more than one issue.
What are the part numbers of the plugs?
Nick
Old Nov 13, 2016 | 08:05 AM
DrDoe's Avatar
The new plugs? NGK 5648 IFR6Q-G
Old Nov 13, 2016 | 09:01 AM
Welwynnick's Avatar
2006 S600
Perfect. A lot of people use V12NA plugs, which cause problems, but those are the right plugs for V12TT.
Nick
Old Nov 14, 2016 | 07:52 PM
DrDoe's Avatar
Took Jack's clues, I decided not to touch anything to see if it would come back by itself.
It did and she's now alive.
Still having occasional restarts at stop lights for #7 misfire. This is really getting old.
Old Nov 14, 2016 | 08:44 PM
Jack_88's Avatar
2018 C300
Glad to see it worked for you, sorry to hear the misfire persists.
Old Nov 14, 2016 | 09:39 PM
DrDoe's Avatar
I just pumped a tank with non-ethanol fuel to see if it would make a difference. Found a Phillips 66 with 91 octane fuel. They used to carry the 87 only.
What are V12TT users pumping?
Old Nov 14, 2016 | 09:52 PM
Jack_88's Avatar
2018 C300
Just your usual 93 gas/ethanol blend for me.
Old Nov 15, 2016 | 09:12 AM
DrDoe's Avatar
I don't have access to 93 ethanol gas. I was pumping 91 ethanol gas until yesterday.
