v12 TT crankshaft sensor
I need to change cps on my 03 s600 v12tt. Engine stalls when hot. Looked all over with no success. I saw s500 v8's But no v12tt. If anyone can direct me to link or web sight or just tell me where or how to change it I appreciate it. Thank you.
In my experience, the camshaft sensor seems to be the issue for warm-up engine.
FWIW, the little false firewall just behind the engine is fairly easy to remove, and will give you lots of space. Climb back there and look straight down, slightly to the drivers side, and see what you have. I usually find a way to snake a socket down there and unbolt them without removing much of anything, but I haven't had to ever change one on a V12
It's not on the fuel system parts diagram. Came back little later said it's in the fuel filter. Integrated together heard it from mechanic. I'm confusing now. 03 s600 150k mi.
I'm near greenwich, CT
johny
000-900-54-09
it connects to the fuel pump, a sensor and a ground.
