Problem installing rear strut
Is there a trick to getting the axle down far enough? It is next to impossible to push it down close to far enough, and then it needs to be pushed out some.
Both wheels are off the ground, swaybar link is out of the car, inner control bar bolt is loosened.
Thanks.
Thanks.
I put the Arnotts in about 5 years ago, and they were great until now. They sent me a new one at no charge.
They went in much easier back then. Can't remember exactly what was different, though. Maybe putting both in makes it easier to move the axles?
Getting the wheel carrier bolted back onto the arm is a little tricky. Put a jack under the end of the transverse arm and lift the arm up to meet the carrier, and then put the carrier bolt back in. Both bolts should go in freely without tools.
Nick
However, the strut is fully pressurized, and when I try to jack the carrier arm up at all, it lifts the car off the jackstand.
I'm wondering if I need to also disconnect the inner mount bolt of the thrust arm to get more play in the axle carrier to push it down far enough to attach the bolt. But, then it may be difficult to re mount that bolt.
I don't have a clue what that means. It is an air strut with a variable-dampening hydraulic shock. It will shorten and extend millions of times during its life.
Did you actually and specifically ask a knowledgeable tech support person at Arnott what you should do? Is that first sentence an accurate restatement of Arnott's advice?
they said it is a difficult install and you have to just push the axle carrier down and out far enough to meet the control arm.
It sounds like the car won't sit at the right ride height then?
I still don't know how I am going to force the axle carrier down far enough to align with the control arm.
If you jack it in the middle, you lift the car up just as much as if you raise the suspension.
You should lift the arm at the outboard end (while allowing enough room to bolt the carrier on).
That will give you maximum lift on the arm and minimum lift on the car.
Nick
