Stuck crank pulley bolt on m275
Old Jul 20, 2018 | 06:43 PM
roberttran's Avatar
2004 S600, 1998 M3, 1974 2002 Touring, 2006 Cayman S
I'm trying to get my m275 crank pulley bolt off but it's impossible right now. I finally found a counter holder that would fit (after some filing) and used a 5ft breaker bar and my entire weight (155 lb). My socket extension just snapped and now I have a hole on my AC condenser too.
Would prefer not to take entire front end off.
Any tips or ideas?
Old Jul 20, 2018 | 07:08 PM
ItalianJoe1's Avatar
2003 CL 600
Other than a bigger bar and extension, it sounds like you are doing it right. If the counterholder is doing it's job, just put a longer handle on the bar (piece of pipe, jack handle, etc), and go for it. Try not to break the fenders
Old Jul 20, 2018 | 09:33 PM
roberttran's Avatar
I broke 2 1/2 drive tools. Ordered a 3/4 inch socket so let's see how that goes. I have a floor mat protecting the fender :-)
Pics of carnage coming once I'm home.
Old Jul 20, 2018 | 09:58 PM
2003 CL 600
Name brand tools or cheap junk? Makes a difference.
I've seen one snap-on breaker bar break, it twisted the end off. Had about an 8' extension pipe on it, with a 250lb person jumping up and down on it.
Old Jul 21, 2018 | 12:28 AM
roberttran's Avatar
Craftsman + a no-name breaker bar
I just ordered a snap-on 1/2 in breaker bar. Hopefully that'll be enough.
Old Jul 21, 2018 | 09:58 AM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
This post brought back some good memories. Stuck crank pulley bolt on m275-photo569.jpg
Get the Husky breaker bar from Home Depot. It worked for me.
Old Jul 21, 2018 | 12:27 PM
wallyp's Avatar
2003 S500 2007 GL450
The 1/2" equipment might not be enough. I had the same problem on a Porsche 928 crank pulley. I snapped a Craftsman 1/2" short extension bar in the center. I could feel the extension and pull handle flexing before it broke. I used a 3/4" drive socket, extension and pull handle, and the bolt moved with no problem.
Old Jul 21, 2018 | 12:44 PM
DrDoe's Avatar
The Husky 1/2 breaker bar worked
