S600 jumps out of gear on load!
Old Jul 12, 2019 | 09:37 PM
Zabe's Avatar
W220 S600 biturbo
Hi guys,
Hoping someone can shed some light for me. The other day I floored it on my s600 2004 and the car jumped out of gear and just reved.
I had lost drive so managed to pull over safely and turned the car off then on and all was ok. Since then the car has been shifting very rough.
Now kickdowns on 3rd gear is very aggressive, it feels like the car is getting kicked in the back very hard.
Pluged in my SDS and I got advised internal fault in component Y3/6 (electrical control module)
What is this?
I also got error codes P2500 (transmission has an implausible transmission ratio
P200E
P200C
All help will be greatly appreciated.
Old Jul 13, 2019 | 09:08 AM
wallyp's Avatar
2003 S500 2007 GL450
One possible cause is the common problem where a leaking transmission electrical connector allows ATF (Automatic Transmission Fluid) to wick up the attached wire harness and into the TCM (Transmission Control Module). The ATF can cause random problems with the TCM. Cleaning the TCM is an easy DIY job. Might or might not fix your problem, but it's easy, cheap, and often helps...
Purchase a spray can of good quality "Brake and Parts Cleaner". Open the right under-hood SAM (Signal Acquisition Module), the lidded black plastic fuse/relay/control box that is located at the back of the engine compartment under the right corner of the windshield. Carefully examine each of the wire harnesses at the top of the box for any traces of oil on the wires. Gently tug the oily harness up and out of the box, bringing the attached TCM with it. Unplug the TCM, and open it, being careful to avoid breaking the plastic latches. Use the parts cleaner to remove all traces of ATF, and let the box dry completely. Reassemble and reinstall. Drive the car a few times to see if this fixed the problem.
Changing the leaking connector is fairly easy, but does require getting under the car. The part is available on-line or at your Mercedes or Dodge dealer, and is usually less than $20. Replacing the connector usually causes only a very, very small loss of ATF during the process. If you don't change the connector, you might have to clean the TCM every five or ten years.
Old Jul 14, 2019 | 02:21 PM
Zabe's Avatar
W220 S600 biturbo
Thank you wallyp
I've actually ordered a full gearbox service kit from Mercedes Also with a conductor plate.
Will have it fitted on Saturday then use my SDS to do a reset on the gearbox and fingers crossed.
The issue I'm having occures only when the car has been driven for a while and is warm/hot.
Old Jul 16, 2019 | 02:02 PM
pmercury's Avatar
member
CL
You'll need to do a "adaptive" function reset possible with Xentry Das only
Old Jul 16, 2019 | 05:33 PM
Zabe's Avatar
W220 S600 biturbo
Already done
Thanks for your reply but I already did this with my SDS but to no avail.
I do hope the conductor plate change with a full gearbox service will rectify it.
I just really hope it's not the main gearbox pump at the front.
Old Jul 16, 2019 | 06:40 PM
pmercury's Avatar
member
CL
what "sds" you have ?
Old Jul 16, 2019 | 07:40 PM
Zabe's Avatar
W220 S600 biturbo
Oem diagnostics equipment
It's the Star diagnostics system Mercedes use
Old Jul 20, 2019 | 06:26 AM
Welwynnick's Avatar
2006 S600
Hi Zabe
Sorry if you already told me this, but do you have the transmission dipstick tool?
First things first.
Nick
Old Jul 20, 2019 | 01:38 PM
Zabe's Avatar
W220 S600 biturbo
I do
Hi Nick,
It's ok no worries. I do have the dipstick and my oil was high. I have now done a full gearbox service again but also with the conductor plate.
Need to test it out now. Seems to better at the moment but I will take it out tonight and I will know for sure when it kicks down on load
Regards
Zabe
Old Jul 20, 2019 | 11:07 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
I had the same problem as mine on the 55 and a trans service fixed it.
Old Jul 21, 2019 | 05:00 AM
Zabe's Avatar
W220 S600 biturbo
Sorted
Hi guys, thank you very much for all your help. It is now sorted and it was the conductor plate as the car is shifting nice smooth again.
But now I have another problem lol
Old Jul 21, 2019 | 09:45 AM
Agent-A01's Avatar
What’s the problem?
Old Jul 21, 2019 | 10:02 AM
Zabe's Avatar
W220 S600 biturbo
Misfire on load
Originally Posted by Agent-A01
What’s the problem?
Its now misfiring on load, at idle or gentle driving it's perfect but when I floor it and revs get to over 4500k it starts to misfire on cylinder 4 and 5.
When I turn the car off then back on, all seems ok again until I floor it and the revs go over 4500k!
Plugged in my star diagnostics and it's coming out with codes:
Misfiring, damages TWC P0300
Misfiring of cylinder 5, damages TWC P0305
Misfiring of cylinder 4, damages TWC P0304
N92/1 ECI ignition module, right bank of cylinders P0300
I took it out for a few more runs but now seems to only misfire on cylinder 4 on load!
Any ideas?
Many thanks
Old Jul 21, 2019 | 10:22 AM
Agent-A01's Avatar
Any ideas?
Many thanks
Sounds like a coil pack. Have you replaced them?
if not, you can rent a coil pack and see if it solves your issue. If it does then you can buy it.
Coil pack/spark plugs are your most common culprit. It could also be faulty injectors but that’s not too common
Also, there is a voltage transformer that steps 12v up to 120v for the coil packs. The car will misfire if that is failing
Old Jul 21, 2019 | 12:50 PM
Zabe's Avatar
W220 S600 biturbo
Misfire on load
The part numbers are different on my coil packs
Right pack is A275 150 04 08 Q1
Left pack is A275 150 07 80 Q6
Spark plugs were changed with NGK IFR6Q-G about a month ago and last year the the voltage transformer was also changed with the updated better version.
Old Jul 21, 2019 | 10:04 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
Any ideas?
Many thanks
The TWC codes are for the catalytic converter. If the O2 sensors dont give good values, the correspunding cylinders are shut down to protect the corresponding cat)s).
You need an SDS "live" read.
Good luck!
Old Jul 22, 2019 | 01:54 AM
pmercury's Avatar
member
CL
misfire on V12 is one of the most discussed questions ever
search in S600 CL600 SL600 S65 CL65 SL65 and V12platform first
