My headlights sometimes flicker, Xenons??
Old Dec 4, 2004 | 03:41 AM
VAHAGN MB's Avatar
2002 S500 & 2004 CLK320
Once in a while my headlights start flickers a split second or 2 , it happens while im drriving on my S500 xenons, 02 model ,, what is that,, is it a short, or is it that the xonons are bad, ???. has anyone else had this happen
Old Dec 4, 2004 | 08:30 PM
Lexino's Avatar
too many to list
i have the exact same problem with my 02 S5 the left headlamp (xenon) flickers sometimes when going over bumps and when not going over bumps and sometimes it turns off comepletey for max 5seconds and turns back on again..its very embarassing and also i get 1 Malfunction Left Low Beam....
Old Dec 5, 2004 | 04:18 AM
VAHAGN MB's Avatar
what do u think it is,, did u fix it??
Old Dec 5, 2004 | 02:21 PM
MB AMG's Avatar
2002 E55 AMG
I think it has to do with the ignitor or something. Not exactly sure. I've seen an ML's xenons flickering like crazy one time.
Old Dec 6, 2004 | 10:27 PM
Lexino's Avatar
too many to list
i think that they are just dying...happeneded again today the malfunction is ( Low Beam, L ) thats the xenon headlight...its dying i called up MB and they said the same aswell..
Old Jan 3, 2005 | 10:49 PM
mbbabe's Avatar
Dying?
What is dying.....the bulb or the ballast?
Old Jan 4, 2005 | 10:06 AM
DMI+RY's Avatar
W220
Also check the contacts for power supply.
Old Jan 15, 2005 | 12:16 AM
Mr.PS's Avatar
What do you mean flicker, When you look at the car coming towards you and the color and intensity changes thats because of the projector the cutoff goes up/down with the road. If its competly going off its a shortage somewhere in the wire which causes the ballast to turn off. Could also be a faulty ballast or capsule.
Old Jan 15, 2005 | 05:35 AM
VAHAGN MB's Avatar
it turned on and off for a split second,, well its not doing it anymore,, so ,,
Old Jan 25, 2005 | 08:47 PM
Playn's Avatar
My 02 S500 Sport did the exact same thing this morning, the left headlamp shut off for a few seconds and then came back on and the same malfunction code appeared that you got
Old Jan 27, 2005 | 04:14 PM
stenen's Avatar
You have too changed the bulb!
Old Feb 14, 2006 | 09:54 PM
lorinserSclass's Avatar
S 430
I changed the bulb and its still flickering..what should I check next..I pulled the back off the light where the power pack for the xenons are..no break in the wire..I hate to take it to MB to get raped..let me know if I can check anything else...thanks
Old Apr 10, 2013 | 10:26 PM
MLCrusin's Avatar
anyone have additional thoughts on this problem? I am starting to experience this 2000 S500 factory xenon
Old Apr 11, 2013 | 02:04 AM
tusabes's Avatar
Mercedes
Get an aftermarket hid kit from the group buy section of this forum , about $60 for a good kit with new ballasts and bulbs
The OEM Mercedes unit will cost $1000+
Old Apr 12, 2013 | 11:33 AM
gorbys's Avatar
S320
It's probably your ballast that's going bad, xenon bulbs rarely go bad. They just color shift and end up going from blue to a pinkish hue with poor light performance.
The ballast is located underneath the headlight, so the headlight needs to come out for it to be replaced.
Old Apr 13, 2013 | 12:29 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Change the bulbs but make sure you change both of them at the same time. Otherwise you will have one light much brighter than the other. The same thing happened to me and after the bulbs were changed no problems.
Old Apr 26, 2013 | 07:10 PM
Stock545i's Avatar
S500
My friend had a flickering issue with her car after installing a pair of cheap aftermarket bulbs. She went back to the factory OEM ones and no issues since then.
GL
Old Apr 26, 2013 | 09:52 PM
Scot Cressman's Avatar
S500
Ive done this twice now. It is the ballasts. I found them on ebay for alot cheaper than normal. Easy repair, just under the headlight assembly. Good luck.
