Keyless Go Lock Doors
HOW do i do this? he he
The manual says something about when you get out of the car, with the keys, you just touch the door handle again and it will lock, the same as when u touch the door handle to unlock it...... i tried this and it didnt work....
someone know how?
thanks!!! =)
Brad
someone know how?
thanks!!! =)
Brad
1 Post
Jeep Grand Cherokee Overland
there should be a little rubber square on the right side of the door handle. press that. grabbing the handle only unlocks it. pressing the square will lock the doors. at least thats how it was on the previous S-Class keyless go.
Is your keyless go on? If I remember right there is a hidden switch that can disable/enable it.
2011 E350 Cabriolet..White and Almond Mocha
someone know how?
thanks!!! =)
Brad
someone know how?
thanks!!! =)
Brad
Originally Posted by Nevada Jack
Just press the little square on the door handle to lock the door...make sure you do not "grab" the handle on the inside part of it...just touch the exterior square button lightly. To unlock just grab the door like you would a normal handle and it will unlock and open.
Note that on the 2007 S550, keyless-go no longer uses a physical button on the door handles. Instead, you will see the outline of a square on the handle that is actually a touch sensor...
Originally Posted by iLoveMyMB
Actually, it's not just the little square. Put ur hand anywhere on the outside door handle and it will lock. The middle, the square, the other side, ANYWHERE!
Bentley Continental GT 2004
I think most owners, myself very much included, took a while to change the old mindset we had where we would grab the door handle and use our thumb to press the square black button to lock the door as with all previous incarnations on Mercedes Keyless Go.
The manual should clarify that gripping the door handle inevitably tells the system to unlock, thus nullifying our attempts to lock the doors by pressing the square body colored touch sensor with our thumbs. Now I use my index finger to give the sensor a poke when ever I leave the car, which works just fine.
