V1 or K40 install on S550 09
Old Feb 12, 2009 | 05:41 AM
avb777's Avatar
09 S550
Hello,
Can anyone share their hiden V1 or K40 radar detector install.
Cost?
Problems?
Any installers in bay area?
V1 or k40 and why?
Thanks.
Old Feb 12, 2009 | 11:40 AM
asg's Avatar
asg
2007 S600
I have the V1 remote mounted under the front bumper witht he Mid City display on the cluster. It works great. Only wish it came with a rear detector. Also have the Blinder Laser Difusser for the front and rear. Very Clean install.
I have he Caliber in my other Car, but don't like that you can't get all the information on the display and its hard to mute.
Old Feb 13, 2009 | 08:14 PM
avb777's Avatar
09 S550
Did the front detector came as a system from Mid City as wells?
What was the cost of your system?
Thanks.
Old Feb 13, 2009 | 11:58 PM
asg's Avatar
asg
2007 S600
Thanks.
I bought the V1 from Valentine. THe Case for the Detector from Mid City $100 and the interface from MidCity It was a few hundred, don't remember, and a few hour for the install.
Old Feb 14, 2009 | 11:27 PM
TimsSL65's Avatar
09' Ferrari Scuderia 16M Spider, 11' Mercedes SL63 AMG, 09' Mercedes S550
I've owned most of the high end radar and laser systems at one time or another. The K40 is the worse! The V1 is much better, but suffers from a lot of false alarms. Take a look at the new Escort GPS based 9500is...amazing technology and performnce. I just swapped the Ferrari and SL65 V1's for this unit, and could not be happier. It has V1 sensitivity, without the false alarms.
Tim
Old Feb 15, 2009 | 11:25 PM
RaDaRkInG's Avatar
Fast Car
The best combination is the Valentine One radar/laser detector and the Laser Interceptor laser jammer.
http://guysoflidar.com/august-2007/r...ctor-test.html
http://valentine1.com
http://guysoflidar.com/july-2008/laser-jammer-test.html
http://www.laser-interceptorusa.com/
Old Feb 19, 2009 | 01:18 AM
avb777's Avatar
09 S550
Would you mind taking some photos of your install? Where does the blinder for the rear goes?
Thanks.
Old Feb 19, 2009 | 09:10 AM
asg's Avatar
asg
2007 S600
Here are some pictures of the Blinder mounteted above the license plate on the trunk lid. The front ones are mounted in vent on the front bumper. The one in the middle on the front is the V1 in its weatherproof case.
Attached Thumbnails V1 or K40 install on S550 09-dsc05531.jpg   V1 or K40 install on S550 09-dsc05535.jpg   V1 or K40 install on S550 09-dsc05534.jpg
Old Feb 19, 2009 | 05:00 PM
avb777's Avatar
09 S550
Thanks for the pictures. Did you have to cut a hole in the vent?
Old Feb 19, 2009 | 05:38 PM
asg's Avatar
asg
2007 S600
yes the mess vent was notched in 3 places to make the blinder and v1 work.
Old Feb 21, 2009 | 03:58 AM
jagata's Avatar
S6 LP640 E500
nice looking install, any pics of the car? My grill is blacked out as well, the garage floor is amazing btw.
Old Feb 21, 2009 | 09:49 AM
asg's Avatar
asg
2007 S600
here are more pictures...
https://mbworld.org/forums/new-s-cla...stom-s600.html
Old Feb 21, 2009 | 09:55 AM
asg's Avatar
asg
2007 S600
now if i could get all the extra junk out of the other garage space, I could actually take some pictures of the gagrage with two cars in it.
Old Feb 25, 2009 | 01:02 AM
avb777's Avatar
09 S550
I think V1 is not going to happen - they do not have a hiden detector and I do not want to cut the mesh and put the all weather box.
Anybody has k40 with the adapter from midcity to show the alarms on the monitor?
Anyone from bay area with photos/price/installer?
Thanks.
Old Feb 27, 2009 | 09:30 PM
RaDaRkInG's Avatar
Fast Car
Thanks.
http://www.1stradardetectors.com/Rad...mote/index.php
Old Feb 27, 2009 | 09:41 PM
suicidal4life's Avatar
2001 E430
Not a W221 but here's my stealth V1 install in my W210 and I think there is a link on my thread to Rocks W211 hidden install. I also have a Laser Interceptor for Lidar.
https://mbworld.org/forums/e-class-w...-pictures.html
Old Feb 27, 2009 | 10:04 PM
avb777's Avatar
09 S550
This is not really a remote unit. You take the radar and put in the weather proof case. Mount it in the front and cut the mesh.
K1 has a small sensor you mount on the front (no holes need to be cut).
And the one for the rear goes inside the bumper not on the license plate (does not need a visible line of sight). I can also integrate it in my command system and show all the alerts in the cluster.
PS: Radarking: I am asking for an honest opinion from other forum members, not an advertisment.
I see you post on every single forum advertising V1 (BMW, MB, Acura, Porsche)
Old Feb 27, 2009 | 10:10 PM
avb777's Avatar
09 S550
Thank you for your reply. However this solution will not work on w221 as S550 has infrared coating on the windows and will not let the signal through.
Old Feb 26, 2014 | 09:23 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Saw this when searching for an acceptable Radar detector install. Never heard this before. Is this true?
{However this solution will not work on w221 as S550 has infrared coating on the windows and will not let the signal through.}
Hd
Old Mar 1, 2014 | 01:10 AM
KeepRtPassLeft's Avatar
1970 220D
No radar detector will work well behind any mesh grill. All grills due to their slots or mesh will attenuate the radar signal. This happens by the mesh or slats bending the radar wave. A simple example is hold your thumb and index finger up to a light. Bring your thumb and finger very close together but not touching. The dark bands you see are due to light being bent and interfering with itself.
A radar antenna can be placed behind a nonmetallic flat surface with minimal or no loss of signal.
Remote installation of a V1 is not smart. The v1 is a very good radar detector, and although other radar detectors are more sensitive than the v1, the v1's rear radar antenna and arrows is what makes it many drivers preferred radar detector. Remote installing it eliminates the usefulness.
The most sensitive remote installed radar detector is the Beltronics STiR+. It is the cousin of the Escort 9500di, but is more user customizable. It has all of the features of the 9500ci minus the laser shifters, and is significantly less expensive. If you chose to purchase laser jammers the AntiLaser Priority is the only way to go. The laser heads are much smaller and perform much better than any other laser jammer. It is the only laser jammer that jams every laser gun.
Old Mar 1, 2014 | 09:56 AM
natcahd's Avatar
Veteran: Air Force
Keep...thanx for the info. Time for homework on AntiLaser. So no worries about the infrared coating on windshield?
Hd
Old Mar 1, 2014 | 10:40 AM
1970 220D
Hd
The thermally insulated windshields generally contain a metallic tint that block transmission of any radio signal. That is why a toll transponder and radar detector won't work on the windshield. On most of those windshields there is a rectangle by the rear view mirror that doesn't contain the insulating material. You can place your tolls transponder or radar detector there.
The Valentine1 is a windshield mounted radar detector. All you need to do is attach the unit on your windshield and plug the power cord into the cigarette lighter (or hardwire the power)
The Beltronics STiR+ is a remote installed radar detector. The radar detector antenna is mounted outside of the cabin of the car (somewhere in the engine bay just behind the bumper cover that does not contain metal) the wire from the antenna get routed through the firewall and plugged into an interface. The rest of the parts of the StiR+ get plugged into the interface; speaker, display, power source, GPS antenna and control module. The speaker, GPS antenna and interface are installed under the dash with the display and control modules installed in locations of your choice. They can be installed to look OEM or in places to conceal their appearance.
The AntiLaser Priority is a laser jammer that is a separate unit from the radar detector. The laser jammer heads are generally placed in the grill. The heads must be placed that they are level to the road surface and the front of the jammer heads are perpendicular to the long axis of the car. They must have a clear (unobstructed) view. They cannot be placed behind the grill. The jammer heads wires are routed through the firewall into the units CPU.
A control/alert unit (it has an LED and piezo speaker) is plugged into the CPU. Additionally, other modules can be plugged into the CPU. A bluetooth module that allows the unit to be controlled and alert to/by an iPhone,iPad or iPod; an external speaker and if desired a radar detection module that allows you to connect the Beltronics STIR+ antenna into the AntiLaser Priority for integration of radar detection and laser jamming into one unit.
https://www.beltronics.com/store/stir-plus.html
http://www.alpriorityusa.com/AL-Prio...g-Systems.html
http://www.raletc.org/2013/09/raletc...fest-2013.html
http://www.miragetools.net/category/news/
Old Mar 1, 2014 | 11:23 AM
natcahd's Avatar
Veteran: Air Force
Keep...thanks again. I read info from the links, this sh*t is deep.
Hd
Old Mar 1, 2014 | 10:39 PM
Mike5215's Avatar
2016 C300
I have a V1 mounted just to the right of the rear view mirror. Wire is run under the front edge of the headliner, under the top of the A pillar on the passenger side, under the fabric insulation strip and then into the glove box to the 12v outlet. Very clean installation (only a couple inches of wire exposed at the unit itself) and works great. I've had it in several cars. No difference in performance in the S.
Old Mar 2, 2014 | 06:38 PM
natcahd's Avatar
Veteran: Air Force
Mike...what does Jason always say besides "2010+" lol? We need video man! Just joking but some pics would be appreciated. Thx again
Hd
