Transmission "shudder" when stopping.
Old Jul 21, 2010 | 11:42 AM
Em Bee Lover's Avatar
CL550 1976 450 SL
2007 4-Matic, 117*** off the line. It has 56,000 miles and been on the ground for 3.5 years. Just got off lease. When slowing to a stop and just before complete stop, there is a strong, noticeable "shudder". It quits when car is totally stopped. To separate from brakes or similar, I put trans. in neutral at about 15 mph and applied steady brakes to come to a normal halt. There was no shudder as it came to a final halt. This isn't right. Am seeing dealer next week. Any ideas? Transfer case (omg, I hope not)? Axle(s)? Motor mounts? Thanks for any and all input.
Old Jul 21, 2010 | 05:11 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
Sounds like transmission problems. I hope you have an extended warranty on the car.
Old Jul 21, 2010 | 06:53 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
+1 omg
Old Jul 22, 2010 | 09:01 PM
nyca's Avatar
It's got 57K miles, it should have have a transmission fluid change at 40K miles. Did it? If not, get one.
Old Jul 27, 2010 | 02:16 PM
rtx2008's Avatar
S400
Same problem
I had this exact problem on an 07 4matic. The dealer at first suspected motor mounts, etc. but the problem persisted. Some time later I had trouble with the engine falling out of gear while driving and progressively losing power. I had to pull over and turn the car off and restart and all would be good for a few days/weeks until it happened again.
Finally the dealer replaced some "electronic valve" and both problems went away. I don't think it was an expensive fix but I was still under warranty.
Old Jul 27, 2010 | 03:00 PM
CL550 1976 450 SL
Transmission "shudder" when coming to a stop.
Timely reply! I visited the M-B shop this morning. Willing to help, but no real distinct answer. Replace motor mounts--$800. Or, change fluid in transmission AND transaxle--$700. Probably should do both. And neither may be a fix. Fluid change first, then he'll drive the car in figure 8's and circles and it should be okay. 100k car and it needs to be driven in circles seems kind of strange.
Please, please, can you retrieve the work order or some how find out what "valve" or whatever was replaced? I will surely pay you or reward you in some way for helping. My car was the 117,123 off the line. Close to yours? If you would find private messaging easier, please do it. I am really desparate. Thanks so much.
Last edited by Em Bee Lover; Jul 27, 2010 at 06:34 PM. Reason: remove potenitally insulting language
Old Jul 29, 2010 | 02:40 PM
rtx2008's Avatar
S400
Looking
Em Bee - Just checked in and saw your post. I'll look for the work order but likely won't have it. I don't have the car anymore. I'll check with my service advisor. They likely keep the records.
Dan
Old Jul 29, 2010 | 02:46 PM
CL550 1976 450 SL
Nutso coincidence. It appears concurrent to you replying, I was sending a private message to you, asking for help. Know you're busy, but any direction will be greatly appreciated. Thanks.
Old Aug 8, 2010 | 11:42 AM
benztech10's Avatar
190e
this is not an uncommon problem, it is in the transmission. it may be software, a ehcu, or possibly mechanical wear. have the dealer check it, they should be able to diagnose it and fix it with out too much trouble.
Old Aug 8, 2010 | 06:11 PM
CL550 1976 450 SL
I appreciate the advice. The dealer said it could be the transmission (duh) or motor mounts. Flush the transmission/trans axle and drive it in hard "figure eight" turns for a while and it should be ok. Estimate--$700. No guarantee of a fix. Replace engine mounts. Estimate--$1000. No guarantee of a fix. That's serious dough to me for guesses. I am really frustrated, but thanks, again, for replying.
Old Aug 19, 2010 | 03:59 PM
ho1105's Avatar
2015 S550, 2015 SL550, 2015 Lamborghini Huracan
Mine had the same problem. Actually the car even stalled on occasion. They fixed the "valve body" and everything is cured.
Old Aug 19, 2010 | 09:20 PM
CL550 1976 450 SL
Transmission shudder
Fixed under warranty? Any idea of cost? Mine has 57 k miles, so it's my nickel. Trying to get a cost idea. Thanks.
Old Aug 20, 2010 | 12:46 PM
ho1105's Avatar
It was under warranty. Fairly common problem for 7G auto. Had similar problem on my R350 which was fixed under warranty, too.
Old Aug 22, 2010 | 02:19 PM
isn't powertrain warranty longer. urs may still be warranted.
Old Aug 24, 2010 | 10:45 PM
CL550 1976 450 SL
"Shudder"
Thanks for kind thought, but power train warr. is 48 months from first use and 50k miles. Sadly, ya don't get much for a hundred k any more.....
Old Aug 26, 2010 | 03:49 AM
Highend's Avatar
C219 CLS / W220 † / W211† / W210 E55 † / W210 Brabus † / Hamann 540i † /
software update. Mine did this if I left off the gas abrupdtly and then applied the brake. If I let of the gas gradually and then applied brake I got nothing. Took it in, reflashed it and BAM, good as new.
Old Sep 2, 2010 | 01:12 PM
CL550 1976 450 SL
Found my answer to two irritants. Vibration through steering wheel at idle and low speeds and "shudder" or vibration at moment of stopping.
Motor mounts replacement cured both ills.
I'm out of warranty. There was a service advisory, which i mentioned to the mb tech, but he ignored. Change transmission and trans axle fluid he said, to fix things. Took to my indie, with service advisory in hand. He said worth the try. Voila'! The old mounts were a full inch + lower/compressed, compared to the new ones. He let everything hang, put on mounts, reconnected and it's like it should be. Shouldn't have to be doing this at under 55,000 miles, but it is what it is.
I owe saving many, many dollars and pinpointing a logical potential solution to this board. The SA listing is phenominal help. The collegial willingness of poster to care and offer thoughts, opinions and experiences was much appreciated. Thanks all!
