Old Jun 16, 2015, 01:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
Print Wikipost
Cracking noise from suspension when going over speed bumps
Old Sep 15, 2015 | 12:44 PM
  #76
RobBanton's Avatar
I ended up going to my indie and he told em the sound now is coming from the right lower control arms and both left and right torque arms. At a tune of $1390 for parts and labor.
Does this sound about right as far as cost?
The S sounds like a horse and carriage right about now. Ha. Thanks in advance.
Old Oct 29, 2015 | 04:30 AM
  #77
Cynical's Avatar
Mercedes S350 2006
Originally Posted by RobBanton
What's the difficulty level of removing and gluing the bar?
Want to bump this question
Old Oct 29, 2015 | 10:52 AM
  #78
xxfightclubxx's Avatar
s550
im not exactly sure what all cost are per each part plus labor. but my car sounded the same way. the noise got worse and worse. ended up being most my ball joints were torn bushings were all messed up front and rear. its going to cost 6000 to warranty company and i have to pay out of pocket a lil under 1000. so for 1390 that doesnt sound to bad. but im sure you can find it cheaper somewhere else or if you buy and aftermarket parts you will save alot.
Old Mar 30, 2016 | 10:27 PM
  #79
belarus27's Avatar
2010 e550 p2
Hello can someone send the service bulletin to belarus27@gmail.com thank you very much
Old Mar 31, 2016 | 05:33 PM
  #80
konigstiger's Avatar
'71 Pinto
Follow link posted in post 61: https://mbworld.org/forums/s-class-w...ml#post6159864
Old Mar 31, 2016 | 08:39 PM
  #81
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2014 S550 (Traded), 2015 GL450
Easiest thing is to get the sway bar assembly replaced. From what I could tell, the bushings come fixed to the sway bar now in the dealer stock so the techs don't have to mess with the adhesive. It'll cost about $400 parts and labor.
Old Mar 31, 2016 | 08:43 PM
  #82
KNBS550's Avatar
Originally Posted by mrbobby
Can't people read. The link is mentioned at least 10 times in this post, Konigstiger, you have the patience of Job.
NO. UNFORTUNATELY, PEOPLE DON'T READ. THEY DON'T EVEN DO SEARCH.
I think there were already three guys asking the same thing about buying KEYLESS GO buttons this year.
Old Apr 1, 2016 | 01:50 AM
  #83
belarus27's Avatar
2010 e550 p2
you know , when you going through pages on your phone sometimes you cant see obvious things , i dont think its that hard to help a brother out and just post a link or the file itself , just like konigstiger did, thanks to him. ) you guys have a blessed day/night
Old Jun 29, 2016 | 10:25 AM
  #84
Mulletmudbogger's Avatar
Bus Honda accord bus
Fixed it!
My new to me 2007 S550 with 220K was doing the same problem. The previous owner had replaced the entire front suspension including the sway bar and could not figure out where the noise was coming from so I bought the car for incredibly cheap. I use a five dollar pack of Loctite adhesive epoxy and let it sit overnight. I followed the same directions as the Mercedes bulletin sanding all the surfaces, cleaning with rubbing alcohol and glued overnight. I generously applied the entire tube of adhesive and wiped away the excess with paper towels. The car now drives PERFECT. I could see on the frame of the car where the swaybar metal mount had rubbed on the metal. This was probably causing some play and the banging noise in swaybar. The only question I wonder is the sway bar would probably be very hard to remove if you had to later change it again, so I would probably only do the glue method to a newer sway bar that has new mounts.
Old Sep 3, 2016 | 01:15 PM
  #85
ioangoci's Avatar
mercedes s class s320 cdi
Do any of you guys get uneven tyre wear? Also, when driving, if you jerk the steering wheel left and right violently, do you get the noise or is only when going over speed bumps?
My car has developed this noise and is getting worse. It only does it when going over speed bumps, or when i raise/lower the car on the jack, so basically only on longer suspension travel. But then, i raised the car, took wheel off, proped a stand under the lower wishbone and lowered the car, it did not make the noise. So it only seems to upset it when load going through the wheel.
Anyhow, i cannot not believe that the fix that MB has come up with, for one of their flagship models, for a suspension component that is subjected to vibration and torque, is to glue it!!
Old Sep 6, 2016 | 11:46 AM
  #86
goosesedan's Avatar
NA
I have a popping sound coming out of my right rear suspension. When i go over speed bumps, the rear of the car wobbles and makes a popping sound, is this the same issue for you guys?
Old Sep 30, 2021 | 09:11 AM
  #87
jschandler's Avatar
S400
I am having the same issue and am going to replace the Sway bar. This is for a rear wheel drive W221. The WIS says that you need to disable the Airmatic suspension via STAR/Xentry before disassembling the sway bar. Is this needed? All else seems straightforward in the directions. I planned on unbolting the linkage on each side then the mounting brackets for the sway bar and replacing.
Old Sep 30, 2021 | 08:47 PM
  #88
Forget all those extra steps. Just unbolt the sway bar from the frame and the sway bar end links.
i think WIS is making it more complicated than it has to be by disabling the airmatic.
Old Oct 1, 2021 | 03:55 PM
  #89
Arrie's Avatar
Originally Posted by Mulletmudbogger
Forget all those extra steps. Just unbolt the sway bay from the frame and the sway bar end links.
And if for some very strange reason Airmatic needs disabled, just disconnect the battery...
Old Oct 2, 2021 | 06:55 PM
  #90
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Disabled air matic reduces risk of inadvertently raising lowering that could harm tech under car.
Old Oct 30, 2021 | 04:54 PM
  #91
solo12c's Avatar
2007 S550
Pls forward a copy to solo12c@yahoo.com
