Got an used S550 but too low mileage.
I just trade in my 2010 E350 with only 3k mile on it, for a 2007 S550 with 20k. I've never drive S before so I want some advice on this model.
It is a 2007, but only has 20k, the tires are original (michelin), but it seems that it has a lot of miles on it. I suspect there is an odometer roll back, but all maintenance records show exactly the same mileage on the odometer and so the carfax history report. So it is possible? a 4 year old car with only 20k but the tire condition it not good?. Do you think this trade is worthy?
Also I can hear some vibration at idle and when I step on the brake padal, feel it on the steering wheel. I can clearly hear the engine running. I check the engine mount and it is fine. I hear something really bad about the early 2007 s engine, the vin of my car is WDDNG86X67A111070 , if anyone can check whether my engine is affected or not, I will be really really appreciate (my English sucks, I tried to explain the situation to the dealer, they just loose their patience)
Thank you in advance.
Also some cars like this are not driven much because well-heeled owners can have lots of others to choose from, so you may have found a genuine low mileage vehicle.
Being cautious is a good thing though. Good luck!
The vibration felt at idle, with transmission engaged. Do you also feel it around the 17-1800 rpm range?
You said you had the "mount" checked. I'd still look closely at the motor mounts. If not still under warranty and you have a good relationship with a mechanic, have him order new mounts. Insure the mech. gets the updated mounts. Have him remove one of the existing ones. Stand that existing one next to the new one. If the existing one is not the same height, there's a good chance the mount is bad. If so, put in the new ones. If the existing mount is the same height, reinstall it and send the new ones back. There'd be some labor and shipping, but at least you'd be able to eliminate mounts as a vibration cause or installing may eliminate the virbration.
My S550 was made 6000 after yours. There are bulletins out relating to vibration/upgraded motor mounts. There are threads here addressing the vibration and mounts, also. I think cars up to 127,000 production had these issues.
Good luck with the car.
Thank you very much!
Thank you very much! Bear with me, seems I have a lot of question,hah.. But I really want to keeo this S for at least 6years. I changed 3 cars from 2010 to now, and finally I got the S, my dream car, I don't want to loose it...
Thank you for your help on my two postings!!!
