Is there a way to adjust caster and camber for our cars? having an alignment issue
I believe the caster is what makes the steering wheel return back to the straight position after you make a turn. My problem is when I turn left at over 60mph or more and my steering wheel is at the 10 o'clock position or lower I find myself fighting to keep the steering wheel in that position. It almost feel like someone is pulling it back the other way. I don't feel it as much when I turn right. It has a slight pull to the right.
Also, is it any different to balance 22" rims than any smaller rims? cause even after they balance rims, I'm still getting vibration at 60-85mph but I find the following sweet spots with no vibration.. 64, 73-75 and 80-83mph
The "vibration". Chk. the tach. Getting the vibes at about 1700 to 2000 rpm? If so, makes sure your engine mounts aren't crunching down and needing replacement. They don't impact the "pull" or "drift", but sure do the vibration felt in the steering wheel. Below and above the range is usually vibration free. Just another variable to monitor.
Caster settings do affect the steering rate of return from a turn to dead center. There is no return with zero caster, but don't know the difference between a minus or a plus setting.
I try to do the first alignment with the dealer to get a copy of the correct settings just in case it gets thrown out of whack and need an indie to do it.
If you feel a vibration in the seat of your pants, it could be a rear tire needs balancing....the steering wheel vibration usually means a front tire needs it.
