s65 AMG exhaust retrofitt
Old Feb 10, 2012 | 06:45 PM
james510's Avatar
MB S550
hi, pleas can anyone tell from the picture below if this is an s65 amg exhaust? it is deffinitly from w221 and I can buy it, but the seller doesn't know from what car it was deinstalled
Old Feb 10, 2012 | 07:05 PM
E36c_AMG's Avatar
I dont think that these are for w221...do you have part number?
Old Feb 10, 2012 | 07:25 PM
_AMG_'s Avatar
C63
Are those exhaust valves?
Old Feb 10, 2012 | 07:36 PM
james510's Avatar
MB S550
the only part number i can get is 221 491 57 00
this should be deffinitely w221 exhaust pre-facelift
Old Feb 13, 2012 | 04:59 PM
RevTekniques's Avatar
'07 S550 Sil/Gry with 2012 S65 Facelight
it is definitely not a W221 OEM S65 exhaust....
Old Feb 13, 2012 | 06:16 PM
james510's Avatar
MB S550
why do you think so? it is a w221 and it has 4 exhaust holes, so it should be from s65 or s63
Old Feb 13, 2012 | 06:43 PM
CarboyS's Avatar
Car
The exhaust tips look nothing like from an S-Class, never mind an AMG. The exhaust tips are part of the muffler and are chrome, the S65 having the tips connected while the S63 had separate exhaust tips, but were lined up.
Pre-facelift S65: http://img.netcarshow.com/Mercedes-B...llpaper_14.jpg
Pre-facelift S63: http://images.caricos.com/m/mercedes...7_1024x768.jpg
Facelift S65: http://www.netcarshow.com/mercedes-b...llpaper_09.htm
Facelift S63 2011+: http://www.carshowp.com/wp-content/u...Angle-View.jpg
Facelift S63 2010: http://600.mywallpapers.org/wallpape...escreen-10.jpg
Old Feb 13, 2012 | 08:09 PM
james510's Avatar
MB S550
tips can be dismounted and also ordered separately, if you have EPC you can check, this looks like pre-facelift s65 without tips
Old Feb 14, 2012 | 12:44 AM
josephpampliega's Avatar
15 MB Sprinter, 14 MB S550, 08 Smart Fortwo, 04 Dodge Sprinter, 87 MB 190E 2.3-16
Had S65 mufflers prior to S63 mufflers. Neither had vacuum operated valve and both outlets were separated by approx. 1.5 to 2 inches.
Both sets of mufflers bodies looked the same other than the tips. Almost looked like the S65 tips could slide onto the S63 mufflers.
You can tell if for S63 or S65 if inlet diameter is approx. 2-5/8" to 2-3/4" in. All others approx. 2-1/4" to 2-3/8" inlet diameter.
Weird how that part number does not come up on EPC.
I suspect those are for the facelifted S550 due to the inlets on the tips are somewhat oval.
Attached Thumbnails s65 AMG exhaust retrofitt-kgrhqvhjc0e7bcvhtu6bozykb-12q-60_12.jpg   s65 AMG exhaust retrofitt-kgrhqrhjcce63yfiju2bozyktpw5q-60_12.jpg
Old Feb 14, 2012 | 02:17 AM
CertifiedMBtech's Avatar
vespa
thats a stock oem s550 exhaust missing the exhaust tips, all s550's come with exhaust tips
Old Dec 27, 2025 | 08:14 AM
ezzat's Avatar
W221.156 S350
Unearthing this thread, not on the bucket list for the S350 but someone nearby has a S65 exhaust (mfd late 2011) for sale in as-new condition from the resonator to the tips. The challenge appears to be twofold:
1- finding the appropriate bumper and diffuser
2- ensuring that the fit doesn't require cutting/welding pipes.
For the first bit, as this is a pre-facelift and wanting to stick to that era, not sure if the facelift exhaust changed tips will fit? check out @Mike5215 's post from 2015
https://mbworld.org/forums/s-class-w...mber-help.html
For the second part, @kociboss says they had to adapt the pipes and that's from a S550 - https://mbworld.org/forums/s-class-w...-amg-w221.html
Both members haven't logged in for a long time, so hoping someone might have had experience with this?
