2013 S Class - Bluetooth Audio not available
Old May 26, 2013 | 05:06 PM
Vivek's Avatar
2010 Mercedes-Benz E350 4Matic
Hi,
So I had posted a thread couple of weeks back asking if I should go for S350 BlueTec or S550 and ultimately decided to pick up S350 BlueTec. Picked up the car couple of days back in Diamond White. Have owned last 2 generations of E Class and this is my first S Class. I am amazed to experience what really S Class is.
While going through settings, etc. I realized that it does not have Bluetooth audio streaming option. Is that true? Could you please help if it can be turned on. And yes, I did turn on the Bluetooth option and my phone is linked to the car but in the Audio menu dropdown I don't see Bluetooth as an option.
Do I need to buy an external bluetooth device and attached it to media interface cable. I am shocked that in 2013 bluetooth option is missing in S Class. In my 2010 E Class it was not available and using one of the threads I was able to turn it on by going into Engineering Mode and it worked. Is there anything similar that can be done with this car?
Appreciate help.
Vivek
Old May 26, 2013 | 05:27 PM
listerone's Avatar
2018 BMW 540d
Although it's hard to imagine that my lowly W212 has BT audio and your vehicle doesn't the quick peek I just gave to the 2013 Comand manual seems to make mention of every type of music input *but* BT audio.I certainly could have overlooked it,however.
Old May 26, 2013 | 11:58 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
BT audio function not available on the 2013 S550.
Old May 28, 2013 | 10:31 AM
peenapple's Avatar
2013 E63 Wagon, 2013 GT-R
Bluetooth streaming does not come standard on S-class or CL-class but you can order the Media Interface Plus unit which will then allow you to have bluetooth streaming. You can order it from your parts department at your preferred dealership.
Old May 29, 2013 | 09:22 AM
S500 Man's Avatar
White S63 AMG W/Designo Interior
peenapple can you get this for 08 s class??
Old May 29, 2013 | 09:24 AM
peenapple's Avatar
Yes, its available for 2007-up.
Old May 29, 2013 | 09:26 AM
S500 Man's Avatar
How difficult to install plug and play
Old May 29, 2013 | 09:28 AM
peenapple's Avatar
It's not hard at all. Pretty much just plug and play and then its somewhat tricky to get it paired up for the first time but after that it's a breeze!
Old May 29, 2013 | 01:41 PM
Super Salami's Avatar
'08 Designo S550, R32 Nissan Skyline
This is still my biggest problem with this car, I realize I have an '08 but I still can't believe this isn't incorporated in the new models yet. I am in a different rental car every week and it pisses me off I can easily sync and stream via BT in pretty much every pos rental but I can't in my S class!
As for the media interface thing, my dealership wanted $300 just to install it! That was an easy 'No thank you'.
Old Aug 1, 2013 | 06:25 PM
AstonLiyanarchi's Avatar
2007 Mercedes S550
Ive looked around for that module and it says that it only works for 09+ vehicles. Has anyone used it in the 07+?
Old Aug 17, 2013 | 09:48 PM
Mandingo's Avatar
W222 S63 AMG
Musiclink ML-D100 if you already have the iPod kit. Works perfectly. $44.
https://mbworld.org/forums/s-class-w...-ipod-kit.html
Old Aug 18, 2013 | 05:58 AM
Diesel Benz's Avatar
Are you referring to bluetooth hands-free instead of audio streaming over BT?
