CHANGING THE BRAKE PADS and *NOT* the rotors?
would i get away with only changing the brakes?
if i do this is it better to change ONLY the pads on the fronts or rears?
Edit: found it, they're 18mm.
as for “18 mm” fasteners are not defined by wrench size, but rather by diameter of the threaded shaft.
Normally Mercedes permits 2 mm rotor wear and it forbids refinishing. If you can feel a lip at the outside of the rotor face, it’s likely at least indicative of 1 mm wear. Don’t overlook the fact this same lip is on the other side too ... so, 2 mm. Additionally, Mercedes cautions against installing new pads when wear is 1 mm or greater ... because the rotor will then be worn out before the pads are consumed ... and you can’t fit worn pads over a new rotor. Basically, then, Its highly unlikely you can fit new pads to a worn rotor.
