w221 check engine light p0071
Old Dec 2, 2013 | 09:33 PM
Gool's Avatar
2010 SLK 350
hey all,
Driving my 2008 S550 today the engine light turns on.
engine scan shows p0071 (ambient air temp sensor
range performance)
the temp on the dash reads +7c
then I checked what the reading on the dash was in my slk and it was +1
Im having a hard time finding the air temp sensor on the bumper.
there is a spot for it near the left fog lamp but no sensor or harness or plug?
does the w221 read off the map sensor for ambient temp?
thanks
Old Dec 2, 2013 | 09:43 PM
mstrbenztech's Avatar
99 E 300TD, 02 E320, 2013 ML350
No, it does read the ambient temp sensor. It is located in the bumper and can be hard to locate. A lot if times water will enter the sensor and give a false reading. Another common problem is the sensor will become detached from its mounting and may rest closer to the engine also giving a false reading
Old Dec 2, 2013 | 09:52 PM
Gool's Avatar
2010 SLK 350
thanks. thats what thought.
i have changed them before on c class and e class even w220 but not on w221
I can see on the bumper where it mounts.
I have pulled the front bumper to find the sensor thinking it had fell behind but like i said there is no trace of it being there.
not even a harness or plug.
weird....
is there another spot?
Old Dec 5, 2013 | 11:42 PM
MagCL's Avatar
CL55, S550, 450SL
It should be there, above the left fog light but closer to the licence plate.
Old Dec 22, 2013 | 11:44 PM
eichstam's Avatar
S550
I had the P0071 error message and ordered a new sensor. The new sensor arrived this week and I installed it today. My sensor was detached from the mount when I removed the front bottom engine cover. I am attaching a few pictures.
Old Apr 12, 2016 | 01:15 AM
asdqwe33w's Avatar
W221 2012 S550
do you guys know where to order the part? Is Rock auto a good place to order part?
Old Apr 12, 2016 | 08:13 AM
alx's Avatar
alx
You want an oem sensor. Rockauto are mostly not oem parts. Parts.com is one of the cheaper sources for oem parts.
Old Apr 14, 2016 | 11:54 PM
asdqwe33w's Avatar
W221 2012 S550
do you guys where I can get the oem part ?
Old Apr 15, 2016 | 12:15 AM
mercedesbenzs55's Avatar
Acura TL 2008 - Acura MDX 2012
Alx told you in the above post. Parts.com = Cheapest OEM parts.
Old Apr 15, 2016 | 03:25 AM
xpl0sive's Avatar
CLS55 AMG
www.oediscountparts.com is a good site for actual OEM parts with an OEM catalogue
Old Apr 15, 2016 | 07:50 PM
asdqwe33w's Avatar
W221 2012 S550
where did you order the parts from? (eichstam)
