2007 W221 S600 exhaust piping questions!
So apparently these cars come stock with an x-pipe already (which I thought should have been a large resonator) and two separate smaller resonators (please see attached pictures).
I think I will keep the x-pipe as-is because well the plan was to remove the resonator and put an x-pipe in (as I did on my 2007 e550) but hey its already there
Now as for the two single resonators, I would like to perhaps replace those with either a straight pipe OR another x-pipe(?), is it even possible to do that? because the spacing looks a bit off, but from researching the forums I keep reading that people are saying to remove the resonators and replacing with an x-pipe but I just don't see how it would fit, or is the muffler man able to kind-of squish the pipes in a little closer to connect the x-pipe?
Any input would help! Thank you! I have attached the photos regarding what I'm talking about!
The best thing to do is, remove the cats that you see from the very front of the pipes. There are o2 sensors plugged in them, so use o2 similators (o2 spacers, aka J-bong), you will not have CEL, and probably gain tremendous amount of power!
Thats what i am doing to my 2012 s550 which also has two turbos! ;-)
The primary cats should be the ones that carry the 02 sensors but those are even further up then the thing in the picture #3 correct?
My next mod is to replace the 2ndary cats and just want to make sure that they are in fact in picture #3...
Thanks guys!
Next step is to find a set of DOWNPIPES! WOOHOO!
