07 S550 Engine Knock/ ticking sound?
Old Dec 22, 2014 | 07:36 PM
ggenius598's Avatar
2007 S550 AMG
Hey Guys,
I have an 07 S550. I drove it yesterday without any issues, I woke up this morning and started the vehicle, it started making a very loud knocking/ticking noise. I popped the hood and it seems to be coming from the engine. I immediately turned the engine off. Are there things i should look at or check first? any suggestion what the problem might be?
Old Dec 22, 2014 | 08:35 PM
cmpcpro's Avatar
2004 CLK 500
I would check the oil first and foremost. How does it look? Low, dirty, metal flakes?
Old Dec 23, 2014 | 04:54 AM
marthyh's Avatar
S500
I remember
https://mbworld.org/forums/s-class-w221/424944-s550-4matic-engine-knocking-tapping-noise-solve-mystery.html
So there is hope, fingers crossed !
Old Dec 24, 2014 | 05:51 PM
ggenius598's Avatar
2007 S550 AMG
Okay, so i did an oil change and i also changed the oil filter, that didnt fix the problem. Im getting a VERY loud knocking/ticking noise. Seem to becoming from the front of the engine. I'm thinking about changing the spark plugs to see if that fixes the problem. Could it be a spark plug/coil issue? Also, does anyone have a DIY on how to change the spark plugs?
Thanks and Happy Holidays!
Old Dec 25, 2014 | 10:15 AM
Nuru's Avatar
S350 BT 4MATIC
From your description, it does not sound like the spark plugs, review the link that was posted and check out that perspective - even though the noise is not coming from the rear of the engine near the drivers side in the thread. Or take to dealer to have them diagnose, then get the parts and fix yourself, if it turns out not to be a huge engine problem. Hopefully it is not something much more serious that the level of repair required by the components discussed on this thread sofar.
Old Dec 26, 2014 | 07:44 PM
RGS's Avatar
RGS
2022 S500 4Matic
Noisy Purge Valve????
Before you get into serious engine work, check the fuel vapor purge valve. It's located right behind the window washer reservoir, attached to a rubber mount. Mine's noisy but is has always been so maybe I'm not as alarmed as you. The unique characteristic to the noise is that it speeds up and slows down and has NO rhythm of the engine.
Good luck.....
RGS
Old Dec 27, 2014 | 05:30 PM
Lexozz's Avatar
2008 S550 AMG Sport
Check out the intake assembly, I spoke to an Indy and he said that part that goes and is costly. Also check out the pulley on the top front of motor.
Old Jan 19, 2015 | 11:33 AM
ggenius598's Avatar
2007 S550 AMG
Okay Guys, Thanks for your input. I did a second inspection and noticed the ac compressor pulley completely came off. I found the pulley laying underneath the engine. The serpentine belt is grinding on whats left of the metal edge of the ac compressor. As a result, i was told the issue is a faulty ac compressor. I ordered a brand new compressor, receiver drier and Expansion valve. Im thinking about doing the job myself. Does anyone have a DIY on replacing these? How hard is it? Thanks
