221 - 2009 Need HELP please "Battery Not Charged"
Old Mar 24, 2015 | 10:37 PM
victorgraur's Avatar
w221 S550 2009 WDDNG86X59A271038
Hello i got my car week a go (W221 2009 4Matik) from first day on my screen was Red message "Battery Not Charged" couple my friend told me is AUX battery but problem is my car have only One battery in front is nothing in the trunk where is suppose to be battery is empty and no wire for battery so never been there a battery.
My front one is after market(not OEM Mercedes) something with 75AH this one also work good and hold power
also i take out small battery under dash check and this one is working good and it hold power
So my be you can suggest me which battery is good for my car or what is the problem.
i have no problem with start and all working good
also my steering wheel buttons on left side don't work also from begin. i though is because red message but now i thing is not
any advices ? or HELP? Please Thank YOU
I have MB STAR if you need something i can give to you quick test on STAR don't give me any error
Old Mar 25, 2015 | 05:43 PM
DaveW68's Avatar
Veteran: Army
2015 S550
If you have the small battery under the hood, then that is the starter battery. Your aux battery would be located behind the panel that is behind the rear seat on the right. Not an easy change-out for that battery or easy to get to.
If everything inside your car works fine....and your keyless go is always working fine along with interior lighting when the car is not started, then the error is likely referencing the battery in your key....which might need replacing soon.
Old Mar 25, 2015 | 09:00 PM
This is screen
i check my car also dealer say my car have only one battery, also today i got OEM battery ordered by my VIN number, and same thing
also i check true MB STAR buttons on the steering wheel and all are working but i cant do nothing on the screen its show me only what you can see on picture
Old Mar 25, 2015 | 09:06 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Try removing positive and negative connections, clean the terminals, then reattach and make sure they are ver tight. It's also possible that you may need to have the battery re-registered to the car.
Old Mar 25, 2015 | 09:21 PM
i did cleaning
How to register batery ?
Please HELP guys
Old Mar 26, 2015 | 08:46 AM
wywywywy's Avatar
W221 S500 SWB
The facelift model only has one battery.
So what are the voltages at the battery terminals, with the engine on and off?
It's possible that the alternator is failing.
Old Mar 26, 2015 | 08:52 AM
Engine off 12.5v
Engine on 13.9v
Old Mar 26, 2015 | 09:19 AM
wywywywy's Avatar
W221 S500 SWB
The engine on voltage is slightly low.
It's worth looking into the voltage regulator I think.
Old Mar 26, 2015 | 09:29 AM
MB STAR say should be 13.4V - 14.5V when is on so my its in range I don't thing also voltage regulator can do something with steering whel buttons , also I founded on this forum couple more people's with same problem and no answer from them if they fix it.
https://mbworld.org/forums/s-class-w...ml#post6377694
Old Mar 26, 2015 | 09:58 AM
sakodik's Avatar
E-Class
Alternator issue! Is your engine making a whiny supercharged sounding noise when you gas it? That was a sign on mine that it was failing, but still charging!
All 2010+ models have only one battery in the front now? Did not know that...
Old Mar 26, 2015 | 10:02 AM
No noise evrething is normal and all working.
Old Mar 29, 2015 | 08:31 AM
PROBLEM SOLVED
Just update IC software to last one and evrething come good nothing else.
thanks to all guys who try to help me
Old Mar 29, 2015 | 08:55 AM
just1time's Avatar
s550
glad you got your problem solved. out of curiosity tho, you mentioned your car is an 09 but only has one battery?
thats news to me. i thought they all had 2 batteries. Even the facelift models.
Old Mar 29, 2015 | 09:57 AM
Hello this is my data card Look at A57
https://mbworld.org/forums/attachmen...x59a271038.pdf
After Facelift then come with one battery (don't know about all) my for shore and it OEM battery 95AH 850 CC. This is original data.
Old Mar 29, 2015 | 11:27 AM
wywywywy's Avatar
W221 S500 SWB
Which module's software did you have to update? The front SAM?
Old Mar 29, 2015 | 11:41 AM
i didant have chance to update SAM first i did IC and all start working so i stop it
Old Dec 26, 2016 | 08:01 AM
El-Roubi's Avatar
Mercedes
I have the same issue , tried to update the IC but no new software found.
any recommends ?
Old Dec 26, 2016 | 10:36 AM
DaveW68's Avatar
Veteran: Army
2015 S550
any recommends ?
Oh....so you drive a "Mercedes". That should make it easy to diagnose.
Old Apr 18, 2018 | 12:52 PM
Alex4493643's Avatar
S550
Originally Posted by victorgraur
PROBLEM SOLVED
I have same problem after replacing battery. How do you update IC software?
Old Apr 18, 2018 | 01:22 PM
konigstiger's Avatar
'71 Pinto
Try this: Start DAS - Information and Communication - IC- Instrument Cluster (Central CAN Bus) - Control unit programming.... - follow the DAS prompts to update the software on the instrument cluster.
2010 221 216 MBUSA released service campaign 201201003 to update IC software due to communication issues. Have dealer check VMI (vehicle master inquiry) to see if update applies to your VIN and confirm it was installed if not, update is free - see attachment.
File Type: pdf
Old Oct 24, 2018 | 02:31 AM
gev2000's Avatar
Mercedes benz CL550
how do u update the software?
