High and low spot on 22" tire
09 S550, 08 Charger Srt8, 63 Ford Galaxie 500, 07 GSXR1000
Hello guys I need your help,
I have an 08 w221 4matic with the factory air ride suspension. I am
getting abnormal tire wear on my 22" wheels. I went to tire kingdom and have had the car aligned twice. My driver side rear tire is the one that has a high and low spot on the tread. here is a picture.
![High and low spot on 22" tire-high-20and-20low-20spot_zps9bqbvsld.jpg](https://mbworld.org/forums/attachments/s-class-w221/374411d1542320533t-high-low-spot-22-tire-high-20and-20low-20spot_zps9bqbvsld.jpg)
One of the techs said that this is due to struts. Before I fork out 600$ for a new strut I wanted to get some feed back from you guys incase you have experienced the same thing.
THanks in advance
THanks in advance
Another issue I am having is the car shakes between 40-60 mph. Had all the wheels balanced and they were find. but I would like to solve the tire wear issue first.
That's feathering.could be caused by any alignment issue, the 22s will only make it worse and I'm sure the rears are wider too?
Yes the rears are 11.5" wide. I have a staggered set up. The tire shop I took it to said it is the struts that cause the chopping. He said feathering is caused by alignment.
He says i Have chopping. I don't think its my struts that are causing this, i feel this is an alignment issue. Tire kingdom has aligned my car twice but I think its time to take it to mercedes benz.
2008 S63, 2012 E550, 2005 E55, 2005 SL55, 2013 SL63, 2020 AMG GT, 1994, 1998, 1999, 2001 SL500
Had the same problem before. Was due to broken belts in the tire. What brand/model of tire are they?
Nobody here locally will even attempt an alignment on an S besides the dealer. I'd definitely get it aligned on the right equipment by an MB tech before digging into the suspension.
Mercedes S550 4Matic
My rear tires only last me the summer due to how low my car is, they wear on the inside inside first, my rears are 295/25/22 . No matter what alignment these cars chew up the rears its normal.
Mike that's cause your running a 275, a 295 is wider so the edges get worn even more. Nothing you can do when you have a lowered car and running extra wide tires that's the price you pay.
He's absolutely right, I buy 4 new continental every summer, I could probably get away with just changing the rears cause the front doesn't wear like the back
SPONSOR
THERE IS ONLY FRONT AND REAR TOE ADJUSTMENT OEM!
WE SAW THE NEED AND MANUFACTURE PRECISELY ADJUSTABLE (SINGLE WRENCH, ON CAR) FRONT CAMBER AND CASTER AND REAR CAMBER (WITH EXTRA TOE) KITS.
WITH K-MAC THE STATEMENT – “FULL FRONT AND REAR WHEEL ALIGNMENT” ACTUALLY MEANS WHAT IT SAYS.
Allowing to fix it right the 1st time – no more ongoing visits to dealers or alignment shops or constantly changing tire brands because of no precise adjustment.
For the front (only) -there are available fluted Camber bolts. But these are inaccurate (one only position) bolts offering a minimal .3 of one degree (1/8”/ 3mm) and require labour intensive disassembly each time. While the K-MAC unique patented design provides for the W221 3 times the adjustment range - single wrench precise/ongoing adjustment capability – on car, accurately (under load) direct on alignment rack.
Allowing to return vehicle to factory specs to accurately resolve steering pull or costly/premature edge tire wear. The result of altering height, load carrying, curb knock damage or fitting wide profile tires/wheels. Added bonus is these 4 front and rear K-MAC adjustable bushings also replace the highest wearing suspension bushings at the same time and have twice the load bearing area. The front bushes are 2 axis self aligning and are designed to also improve brake and steering response
CAMBER – Allows to actually change the tire contact angle, improving wear/ traction/understeer/oversteer
CASTER –Resolves steering pull, increases steering response. With better turn in and high speed directional control, along with improved anti dive/lift under brake and acceleration.
For the rear - you can purchase adjustable Camber rods but to reduce inner edge tire wear unlike K-MAC lower arm bushings – these rods need to adjust top of tire outwards which reduces all important clearance to outer fender. K-MAC kits also include extra Toe adjustment - necessary to compensate for this new rear Camber facility.
W211Front Kit #502316K $480
W211Rear Kit #502526K $480
Current promotion for MB World members USA/Canada delivery - $30 one kit or $40 front and rear (normally $70 one kit, $80 front and rear). Can pay by Visa, MasterCard or PayPal.
See link for latest 2015 catalog Audi to Volvo – World’s largest range
http://K-mac.com/mercedes/
![](https://mbworld.org/forums/attachments/c-class-w204/283700d1397109035t-need-drop-what-do-you-suggest-4.jpg)
![](https://mbworld.org/forums/attachments/wheels-tires/286602d1399954231t-20-incurve-wheels-cls-sl-ferrari-grey-5.jpg)
Yeah I love the way the wide rears and a drop looks but I'm not into forcing the car to fight its tires. I'm a big baby when it comes to anything that might deteriorate the ride.
2008 S600, 2011 Ducati 1198
I have both of my front rims somehow bent/out of round is more the term. I also have the shaking at 40-60 and then a little more when you go faster. I had taken the car 3 times to tire kingdom/NTB and they couldn't figure it out. Ultimately, I went to another shop and had them look at it on the lift and based on the tread wear they concluded that it was a bent rim on both front wheels and then they spun the rims and showed me while it was on the lift and you could see the out of roundness on the rims. Hope it helps! Its about 100/rim at the place I go to for rim fixes
+1 on bent rim,
I have both of my front rims somehow bent/out of round is more the term. I also have the shaking at 40-60 and then a little more when you go faster. I had taken the car 3 times to tire kingdom/NTB and they couldn't figure it out. Ultimately, I went to another shop and had them look at it on the lift and based on the tread wear they concluded that it was a bent rim on both front wheels and then they spun the rims and showed me while it was on the lift and you could see the out of roundness on the rims. Hope it helps! Its about 100/rim at the place I go to for rim fixes![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I am about to replace both rear tires and take it to MB to see if they can do a better job of aligning the car.
your problem is your 22" rims. they are probably too heavy and fall outside of the ability of the stock shocks to quell/ damper them over rough road. the result is unchecked wheel hopping (some times felt some times not) that creates the high/ low spot on your thread and also generally crappy ride, handling, noise... you name it.
stay tuned for your steering rack to go out next due to the added weight.
