2007 s550 command module issue - no display
Old Oct 22, 2015 | 12:23 PM
xdsmx's Avatar
01 CL500
So is this the command module or voice command module or is it one in the same?
Display all of a sudden started flashing the mbz logo like it was trying to boot. As of now I only have AC controls and nothing else on the screen. Tried system reset (eject button) and disconnecting batteries for 15ish minutes, no luck. Dropping it off tomorrow at my Indy shop for repair unless it's an easier plug and play fix. Thanks guys
Old Oct 22, 2015 | 12:34 PM
Mike5215's Avatar
2016 C300
Sounds like a bad COMAND. Bummer. They're expensive. Hopefully your Indie can sort it out.
Old Oct 23, 2015 | 10:37 AM
xdsmx's Avatar
01 CL500
Is the command unit the same piece as the voice command module? Tried searching this issue and that's the only thing I can find on both mbz forums
Old Oct 23, 2015 | 11:36 AM
konigstiger's Avatar
'71 Pinto
Head unit...
Old Oct 23, 2015 | 12:14 PM
xdsmx's Avatar
01 CL500
The head unit/display seems fine. I'll get the mbz logo at times and the command safety warning. The ac controls are on there as well just no audio or nav functions
Old Oct 23, 2015 | 12:22 PM
'71 Pinto
Need to pull fault codes with MB DAS.
Old Oct 23, 2015 | 04:56 PM
xdsmx's Avatar
01 CL500
System needed an update, all is well thank god.
Highly recommend mark @ just German in Tampa if anyone needs a euro service shop that doesn't overcharge or lead you in the wrong direction
Old Jun 5, 2016 | 09:41 PM
bamaclk430's Avatar
99 clk 430
need help or advise S550 2007/ head unit keep trying to reboot at morning start up. comes on about 30 minutes into drive
Old Jun 5, 2016 | 10:23 PM
Mike5215's Avatar
2016 C300
Get it in for a diagnostic. Sounds like the hard drive may be starting to fail.
