excessive tire edges wear 2007 s550 base car
the new set of Michelin pilot sport a/s has only about 10k miles but both inner and outer edges of all 4 tires are almost worn down. wear pattern is similar on all tires. same wear as the previous set.
I noticed that the wear areas on the edges are darker shade vs the center thread areas. looking at the tires with the car parked, these dark edges are not touching the pavement. I think this is from rubbing when cornering. I upped the tire pressure to 35 psi cold. did not help. the car has no alignment issues.
I am told that this is due to the car weight and cornering speed. so does it means that this tires were not designed for this car? or maybe use an XL load rated tires or ones with higher UTQG? I am now looking at replacement tires. appreciate any ones experience on tires for their S550 with 18" oem wheels. my own research shows Continental extreme conta ct dws 06 is my best bet followed by Kumho ECSTA LX platinum k and Goodyear Eagle F1 asymmetric a/s.
Unless you get an actual AMG car (S63/65) with the ABC suspension, or happen to get a base car that got the ABC as an option. Those cars stay flat in the corners. Spacers all around might help with wear around the outer edges and improve handling a bit. 20mm rear and 15mm front is as far as you can go on OEM offset rims without rolling any fenders.
I'd either toss it around less or plan on buying tires more often.
Your situation almost sounds like the tires are under-inflated. Under-inflation usually causes excess but even wear on the outside edges of tires, while over-inflation causes excess but even wear on the centers of the tread. I would look here first, as often shops will under-inflate tires on "luxury" cars to make them ride softer, even though their suspension is not designed for pillow-soft ride.
Initially I inflated it to the recommended pressure of 29-30 psi. as I noticed the wear pattern which is the same on all tires and no sign of feathering, scuffing nor cupping, I decided that I need more pressure to increase the contact of the central thread area. Increased pressure to 34 psi. Still same result. Viewing the car tire when parked, I can see that the worn edges are not in contact with the ground surface. These edges are darker in color compared to the central tire thread area. So it is rubbing during turns as it deflects. As far as my driving habit, I do not push the car any harder on corners the same way I drive my 2005 Corolla, 2003 GMC Envoy, or 96 Impala SS. all these cars do not share the same tire wear pattern as the S550.
Having read all the comments, my inclination now is to try a set of tire with xl load rating, higher UTQG, and wider thread. So far the best candidates are: Continental Extreme Contact DWS 06 except tire width is even lesser than the Michelins now. Yokohama Avid Envigor or YK 580 meets all criteria with wider thread. Yokohama reviews not very good.
So, am I on the right tract in finding a solution to this tire issue or no matter what tire...
I will try the Continental Extreme Contact DWS O6. I hope the higher UTQG, and XL load rating will help reduce this issue.
Because of this issue you can get new tires for a discount from where you bought them. If the tire is still in warranty.
In this discussion, most static measurements are in spec: tire pressure, alignment, etc. Dynamic factors have not been addressed. Excess toe-in and out can be the result of tire spacers and soft bushings.
I would start with removal of any tire spacers and inspection of the suspension's soft components.
Suspension design: definitions and effects on vehicle behavior - Car Engineer
www.car-engineer.com › suspension-desi...
WE SAW THE NEED THEREFORE TO MANUFACTURE AND REINSTATE FROM THE EARLY 90’S PRECISELY ADJUSTABLE (SINGLE WRENCH, ON CAR) FRONT CAMBER AND CASTER AND REAR CAMBER (WITH EXTRA TOE) KITS. NO MODIFICATIONS – SIMPLY REPLACES THE 4 FRONT AND 4 REAR HIGHEST WEARING BUSHINGS. ALLOWING “ONGOING FULL ADJUSTMENT” TO FIX IT RIGHT THE 1ST TIME!
ESSENTIAL IF WORN BUSHINGS, ALTERING SUSPENSION HEIGHT, LOAD CARRYING, FITTING WIDE PROFILE TIRES AND/OR CAPABILITY TO RETURN TO FACTORY SPECS AFTER CURB KNOCK DAMAGE.
CAMBER – Allows to actually change the tire contact angle resolving costly, premature edge tire wear, improving traction/understeer/oversteer (TOE only alters wheel direction).
CASTER – Correctly resolves steering pull, increases steering response. With better turn in and high speed directional control, along with improved anti dive/lift under brake and acceleration.
No more ongoing trips to dealers or alignment shops or constantly changing tire brands because of Toe only adjustment OEM. Or the frustration of installing (Front only) ‘offset’ bolts – to find they are inaccurate one only position – offering a minimal .3 of one degree!
We have changed all that. Up to 4 times the adjustment range of these “one” position bolts. With single wrench precise adjustment and importantly on car accurately (under load) direct on alignment rack!
This K-MAC patented design breakthrough of on car adjustment has also eliminated the need over the last 40 or so years of time consuming disassembly each time to change settings.
Front bushings have twice the load bearing area of OEM. Yet still 2 axis/self aligning without the use of oil and air voids. Allowing also improved brake and steering response.
Rear bushings provide precise Camber for the first time and extra Toe to compensate for the new Camber facility.
Both front and rear kits come with instructions and bush extraction and insertion tubes.
W221
Front Camber and Caster kit #502316K $480
Rear Camber (and extra Toe) kit #502526K $480
MB World members (USA/Canada) delivery $30 one kit or $40 front and rear.
Can pay by PayPal or call our toll free number 1888 414 0762 to quote Visa or MasterCard.
front 29, rear 29: at max 100 mph
front 32, rear 33: at over 100 mph
Which is the same data on label on the driver door B pillar.
On the Michelins I put it at 35 psi which did not help.
The Continentals initially inflated at 30. I drew several white paint lines across the thread of each tire and drove it around to see the contact surface extent of all the tires. the edges were rubbing again. I increased the pressure until the contact patch do not extend to the tire edges. it turned out that the pressure should be at 37 psi minimum.
I will drive it several days to see how this set up works. Too early to make a conclusion. I was surprised that the ride on these Conti's are not as harsh as the Michelins at this pressure. Also it appears to roll/ride better. Just a perception, could be psychological.
Thanks again. By now several people I talked to agrees it's a tire issue, not a car issue. The Michelins were not up to the normal wear performance expected of the tires rating FOR THIS CAR.
