Loud Creaking Noise front right side tire
Old Apr 3, 2016 | 12:27 PM
bmwcrocop's Avatar
2007 s550
I noticed a loud creaking noise from the front right side by the tire. It goes off when I push the front up and down, moving the tire left and right, slow and fast speeds.
Last time this occurred I replaced the thrust arm bearing and nut about 50,000 miles ago.
What does everyone think this is?
Which parts should I order?
Thanks in advance.
Old Apr 3, 2016 | 01:31 PM
mercedesbenzs55's Avatar
Acura TL 2008 - Acura MDX 2012
upper or lower control arms perhaps. Does it do it when going over a speed bump?
Old Apr 3, 2016 | 06:35 PM
bigkev21's Avatar
2010 S550 4-Matic
Thanks in advance.
I just had the same thing and it was the lower control arm. Not sure what the part number is. It was covered under warranty.
Old Apr 5, 2016 | 09:00 PM
bmwcrocop's Avatar
2007 s550
I ordered the bearing; hope I don't need an arm. Ill post the results.
Old May 11, 2016 | 01:09 PM
jenz's Avatar
S, GL
AMG brakes? You'll see individual AMG take offs on eBay, just pick up an OEM rim and mount a comparable tire.
Old May 11, 2016 | 11:05 PM
GPrime2's Avatar
2007 Mercedes S600
When you say moving the tire left and right, do you mean from a stop or while cornering?
Old May 12, 2016 | 09:48 AM
bmwcrocop's Avatar
2007 s550
Turning the wheel left and right
Old May 18, 2016 | 06:19 PM
bmwcrocop's Avatar
2007 s550
Lower Control Arm cured it. $580 for arm and labor + the initial bearing replacement.
Old May 18, 2016 | 07:40 PM
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2014 S550 (Traded), 2015 GL450
This is the same issue as your other post about a 'squeaking' noise right???
Old May 19, 2016 | 07:13 AM
bmwcrocop's Avatar
2007 s550
Yes problem solved
