Engine Issues
Old Jul 16, 2016 | 01:52 PM
bmwcrocop's Avatar
2007 s550
Engine Issues
The engine is very rough when starting up and has low power when accelerating.
After start up the engine light flashes five times and then stays on.
The codes that show up are: P0335, P0444, P0300, PO307 and P0308.
I changed the spark plugs and crank shaft sensor to no avail. I previously changed out the charcoal gas filter.
Thoughts?
Thank you.
Old Jul 16, 2016 | 02:25 PM
konigstiger's Avatar
'71 Pinto
0703 P0335 B70 (Crankshaft Hall sensor): Check wiring of signal line and voltage. (P0335)
0851 P0444 Y58/1 (Purge control valve): Open circuit / Switchover valve permanently closed (P0444)
0629 P0300 Misfiring (P0300)
0630 P0300 Misfiring (P0300)
0632 P0300 Misfiring (P0300)
0657 P0307 Misfiring of cylinder 7: Damages TWC (P0307)
0658 P0307 Misfiring of cylinder 7: Worsening of exhaust emission values (P0307)
0660 P0307 Misfiring of cylinder 7: Worsening of exhaust emission values after engine start (P0307)
0661 P0308 Misfiring of cylinder 8: Damages TWC (P0308)
0662 P0308 Misfiring of cylinder 8: Worsening of exhaust emission values (P0308)
0664 P0308 Misfiring of cylinder 8: Worsening of exhaust emission values after engine start (P0308)
Next step, swap coil packs to different cylinders if fault code follows, replace affected coil packs. If not and engine # is within range, perform compression test “may” be cylinder head. See bulletin here: https://mbworld.org/forums/cls-coupe...ml#post6857762
Old Jul 16, 2016 | 03:23 PM
bmwcrocop's Avatar
2007 s550
Ill check the coil packs next. Is there a certain order for the coil packs?
Engine Number: 27396130013673
Is there a recall? Is mine affected? What is the cost?
Old Jul 16, 2016 | 04:27 PM
'71 Pinto
273 5.5 engines produced up to 11/09, clean point 30 342934. No recall or service campaign, bulletin so no coverage out of warranty. If vehicle is regularly serviced by MB dealer, MBUSA may offer goodwill assistance towards repair “if” this is your problem. Follow link in previous post to save bulletin.
Removal: http://workshop-manuals.com/mercedes...and_operation/ + next pages
Old Jul 16, 2016 | 09:35 PM
alx's Avatar
alx
Coils or spark plug controller
Old Jul 17, 2016 | 06:21 PM
bmwcrocop's Avatar
2007 s550
Could it be a module or fuse somewhere?
Old Jul 17, 2016 | 09:02 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Not likely. Probably a bad coil pack or two.
Old Jul 18, 2016 | 08:59 AM
bmwcrocop's Avatar
2007 s550
How do I determine which ignition coil is bad out of the 8 individual ones?
Thanks in advance.
Old Jul 18, 2016 | 09:31 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Thanks in advance.
Look at post #2.
Old Jul 18, 2016 | 11:09 PM
bmwcrocop's Avatar
2007 s550
Two dumb questions:
Which cylinders are 7 and 8?
If I switch the coil packs would the new codes be P0306 and P0307 (just and example) -- thereby concluding it's the cool pack?
Old Jul 18, 2016 | 11:14 PM
bmwcrocop's Avatar
2007 s550
Is this
Is this picture accurate ?? Can't tell which car
Old Jul 19, 2016 | 11:56 AM
'71 Pinto
In your case you do not need the firing order but rather cylinder layout, see capture (shown in link previously provided).
Old Jul 20, 2016 | 10:09 AM
bmwcrocop's Avatar
2007 s550
Thank you sir
Old Jul 25, 2016 | 08:06 PM
bmwcrocop's Avatar
2007 s550
I replaced coils 7 and 8. After 10 seconds the engine light flashes and then begins to pound. Sounds like it's sucking in air.
Appears to be heavy on oil as well.
Anything else to try?
Old Jul 25, 2016 | 08:08 PM
bmwcrocop's Avatar
2007 s550
I replaced the back two right coils -- if I am facing the engine.
Old Jul 26, 2016 | 02:05 PM
bmwcrocop's Avatar
2007 s550
In your case you do not need the firing order but rather cylinder layout, see capture (shown in link previously provided). Firing order driver side 1/3/5/7, passenger 2/4/6/8.
Konigstiger,
Thank you for the post. I viewed the provide picture and it shows that cylinder 7 and 8 are the last two on the drivers side. However your statement "Firing order driver side 1/3/5/7, passenger 2/4/6/8" implies cylinder 7 is on the driver side and cylinder 8 is on the passenger side -- which would indicate the drawing is inaccurate.
Please clarify. Thank you in advance.
Old Jul 26, 2016 | 02:34 PM
'71 Pinto
Removed, cylinder order is correct in link & image provided.
Old Jul 26, 2016 | 02:56 PM
bmwcrocop's Avatar
2007 s550
Aww man; thought I had something.
Just bought a code reader and going to analyze the codes and see what the difference I post install. Will post results.
I also purchased the MB Wisa/Aria and EPC diagnostic tool.
If all else fails will check compression and cylinder heads.
Old Jul 30, 2016 | 11:00 AM
bmwcrocop's Avatar
2007 s550
UPDATE:
The code reader came. I replaced cylinder 7 and 8 coils and spark plugs which cleared PO300 and PO307.
The only code that remains is PO308.
I switched wires from 7 cylinder to 8 and 8 still misfires.
Are there any other things that I cam do our test before I go to the compression test?
Thank you.
Old Jul 30, 2016 | 11:16 AM
bmwcrocop's Avatar
2007 s550
here is a picture
Old Jul 31, 2016 | 02:34 PM
bmwcrocop's Avatar
2007 s550
What do you think about switching our the fuel injectors?
Old Aug 1, 2016 | 06:12 PM
kn51's Avatar
2007 S600
What do you mean you switched wires? When you switch them to the plug/coil pack you are really screwing up the firing order.
Guess swap injector 8 with 7 and see if misfire follows to answer your question on the injector.
Old Aug 2, 2016 | 11:14 AM
bmwcrocop's Avatar
2007 s550
I am taking the POS to a Benz mechanic for a diagnosis. I'll report back in the findings.
The 2007 S550 is plagued with engineering and material defects. Whenever I fix one problem another occurs.
I'm going to fix it and sell it. G class is on the radar.
Old Aug 2, 2016 | 06:00 PM
alx's Avatar
alx
ugh. be careful what you wish for. the g class has some very serious drivetrain issues on its own. it is a fairly simple vehicle to fix, but it is very expensive parts-wise.
Old Aug 3, 2016 | 01:55 AM
sloanbj's Avatar
'72 Fleedwoot
If you don't like endless reliability woes, a Land Cruiser would be a better bet. They hold their value better as well.
