2007 s550 rear window don't work
Old Feb 18, 2017 | 05:02 PM
clifton wright's Avatar
s550
Read window don't work
Old Feb 18, 2017 | 06:04 PM
marthyh's Avatar
S500
Left or right ?
Old Feb 18, 2017 | 10:38 PM
DaveW68's Avatar
Veteran: Army
2015 S550
That's nice! Very informative for your first post.
Old Feb 19, 2017 | 05:29 AM
marthyh's Avatar
S500
Give the man some time to figure out which one it is ..
Old Apr 4, 2017 | 06:09 PM
vans726's Avatar
2007 S550
I have a 2007 S550 and it started with my front passenger window stop working, then the left rear window, followed by the right rear window. My mechanic suggested that the module be changed. Now I only have the driver side window working and I'm worried it will stop working too.
Appreciate any suggestion on what might be the problem......
Old Apr 4, 2017 | 09:51 PM
MonroeHandyMan's Avatar
2007 S550 4Matic 2009 ML350 4Matic
Try the obvious first, fuses, kinks in harness from door to body. Most likely you will have to take it to Mercedes and have them reset the window motor modulators. I had that done on one of my windows last year as it stopped working. Mercedes reset it and no problems ever since.
Old Apr 5, 2017 | 08:37 AM
alx's Avatar
alx
the car is methodically working towards entrapping you. once all four windows are inop, all of a sudden the central locking will malfunction and your days as a free man are over. you have been warned.
or... on a more serious note - reset of the door modules usually take care of this. while at it the pinch and hal sensors can be interrogated- they do go bad and when they do the module fails the window operation.
edit: as konigstiger mentioned there is also a module software update that can be applied if your car falls within certain vin range. the update prevents a crash in the module which renders it inop. a reset as i mentioned fixes it... until next crash which is usually very rare, but does happen. the update prevents the crashes altogether.
Old Apr 5, 2017 | 10:52 AM
konigstiger's Avatar
'71 Pinto
Before replacing module consider updating software if within VIN range per bulletin attachment here: https://mbworld.org/forums/s-class-w...ml#post7099789
Old Apr 5, 2017 | 03:35 PM
vans726's Avatar
2007 S550
Do I just request for window software update at the dealership? Thank you!
Old Apr 5, 2017 | 06:01 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Print the service bulletin that Konig provided and take it to your dealer. Many dealers will give you a baffled look unless you show them exactly what is needed.
Old Apr 6, 2017 | 11:08 AM
alx's Avatar
alx
just tell them to hook up your car to star/ das and interrogate the 4 door modules. star/ das will automatically prompt to update firmware if it is needed.
Old Sep 11, 2017 | 04:58 PM
vans726's Avatar
2007 S550
Is $350 reasonable for an independent mechanic to charge for module software update for 3 windows Took me awhile to handle this and finally did it and all 4 windows are good now, just not sure if the price he charged was reasonable.
I would appreciate referral for a MB mechanic in Los Angeles if some of you know one. Thanks!
