2007 s550 no radio no display no back up cam HELP!
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
Hey guys I have a 2007 s550 and for about a week now I have no audio no navigation and no back up camera, I have checked the fuses and everything seems to be fine would you say it's the command unit?
Received 4,435 Likes
'71 Pinto
Check 122 @ rear SAM (141 is for camera) see attachments. If fine best bet is to have someone pull fault codes using MB DAS (diagnostics).
Your head unit is gone. It is the common denominator for the nav/ radio/ backup camera. Once pulled out you can remove cover and check internal fuse. If fuse is good unit is bad. If fuse is good replace, but will probably burn again. New unit needs to be scn coded to car.
Please help
hey guys I’m having the same issue as Eppscobar2211. I have no stereo, no navigation, no back up camera on my 2009 s550. Basically I can control nothing my on command control unit beside just turn the ac off and on. Someone please help
Only climate control working
Hey I’m having the same issue now. How did you fix it?
