s550 motor mounts
Old Feb 9, 2020 | 01:02 PM
BENZOBLACK's Avatar
S550
s550 motor mounts
my car has 67000 miles and im being told motor mounts need to be replace . how much is a fair price to pay
Old Feb 17, 2020 | 01:21 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
I have a 2012 s550 4Matic, 99k miles. Replaced 2 Motor mounts and transmission mount for $1600 by Indy. Got quotes over $2K from other Indy's. If you don't have 4M then should be a lot less. My guy had to disassemble a fair amount of the undercarriage crossbeams, steering linkage, etc. to get at the mounts, then an alignment job. Do you have vibrations at idle and up to 1600 RPM when underway? This was the symptom I had that told me they needed to be replaced. Same for my 2007 SL, had the mounts replaced and no more vibrations, just like brand new now.
Old Feb 17, 2020 | 02:34 PM
Ninamashr's Avatar
2010 S550 Black on Black
Did my own, 2 motor mounts and 1 rear trans mount, for under $200 in less than 4 hours. You need to buy a special offset tool, $25 from Amazon, to loosen the engine mounts and a jack to lift the engine a bit to take out the mounts. After getting them installed the car was so quiet, I now can't even hear or feel the engine when i'm at a stop light, amazing!
Old Feb 18, 2020 | 07:18 AM
PillDrive's Avatar
2003 S55 (SOLD) , 2012 S550
Ir depends on what year your S550 is.
2012 and 2013 has the M278 Twin Turbo Engine and the procedure and parts are different.
Old Oct 3, 2020 | 11:03 PM
Hatzenbach's Avatar
2009 W221
@Ninamashr can you give me the link to the offset tool please?
Old Oct 6, 2020 | 04:29 PM
Ninamashr's Avatar
Here you go amigo...
https://www.amazon.com/Jtc-4693-Engine-Fixing-Screws/dp/B06XQ6DGZM/ref=sr_1_1?dchild=1&keywords=jtc+4693&qid=1602016309&sr=8-1 https://www.amazon.com/Jtc-4693-Engine-Fixing-Screws/dp/B06XQ6DGZM/ref=sr_1_1?dchild=1&keywords=jtc+4693&qid=1602016309&sr=8-1
Old Oct 6, 2020 | 10:15 PM
Hatzenbach's Avatar
2009 W221
thank you
Old Apr 5, 2022 | 09:06 PM
bendz's Avatar
2013 S550 4 matic
S550 motor mounts
I have a 2013S550 4 Matic that needs mounts. Please tell me how you did yours so quickly. Thank You, Kirk
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
