NTG3 Engineer Menu
Old Sep 27, 2021 | 10:27 PM
skylinehk's Avatar
CL600
NTG3 Engineer Menu
Hello All,
I recently got a carplay to retrofit my 07' w221. Everything works except I need to activate AUX/TV in the COMAND to enable the voice transmission.
I have tried 3-5-7 and *-1-hangup trick but both did not work.
Can anyone help me out? Thank you guys!
Old Sep 28, 2021 | 10:20 AM
BOTUS's Avatar
S500
check the post on NTG clock fix
its a complex procedure took 14 years before this became public on the S class - not sure if aux on is in there...
Old Nov 14, 2021 | 07:06 PM
ABEY Ismail's Avatar
W221 s550 , w212 e550 , nissan patrol
Engineering menu w221
1# switch off the command system by pressing on /off button or going to vehicle and select display off .
when it turn black
2# push the knob to right side and at same time press the seat massage button and the mute button at the same time , and you will be in the engineering menu .
Cheak this video it's in Arabic language but hope you can understand
Old Dec 7, 2021 | 06:22 PM
matiuscomputers's Avatar
w221 S 500 Long
I have try it but it does not works for me. My Mercedes is 2007 W221 NTG3.0 S500 Long.
When I perform your recomendations.
I've try first knob to the right and then seat massage button and the mute button at the same time (but the screen keeps going black).
then I try all three things at the same time and the screen is black again.
Can you help me please?
Old Dec 8, 2021 | 12:41 PM
BOTUS's Avatar
S500
why not do as I put and read the instructions on the other thread
Old Dec 8, 2021 | 04:27 PM
w221 S 500 Long
how do I get to that other thread?
Old Dec 9, 2021 | 07:52 AM
BOTUS's Avatar
S500
its the one 38,000 other people noticed - check the PDF
https://mbworld.org/forums/s-class-w...ml#post8455957
Old Dec 10, 2021 | 08:58 AM
w221 S 500 Long
Thank you very much for your help.I was able to get to the engineer menu, but couldn't find a place to turn on the AUX sound.
My Mercedes may not come from the factory with this item.
Anyway thank you very much and excuse my clumsiness.
Old Dec 10, 2021 | 12:43 PM
BOTUS's Avatar
S500
as I mentioned previously "not sure if aux on is in there" ....it can be turned on using dealer kit in less than 10 minutes - its on all the cars, all you do is display the choice (or not)
Old Dec 10, 2021 | 03:00 PM
w221 S 500 Long
Thank you very much really.
I will try in Mercedes WorkShop
Old Dec 11, 2021 | 03:41 AM
BOTUS's Avatar
S500
ummm, whilst Aux was always there (but menu doesn't show if not enabled) it would be wise to have the latest comand telematics software on all modules (they all link via its fibre MOST and update in a chain)
just thinking way back, there were a number of features that were introduced and lots of bugs that they resolved. if you are pre 2008 update the whole comand is a box of muddled junk.
the easiest way to see if you are anyway near up to date is to look in Nav map views and see if the option alongside north up etc, has "Bird's eye view"
https://mbworld.org/forums/s-class-w...pdate-diy.html
Old Dec 11, 2021 | 03:44 AM
BOTUS's Avatar
S500
this is quite a cool OLD post
https://mbworld.org/forums/s-class-w...ries-work.html
Old Dec 21, 2021 | 01:35 PM
w221 S 500 Long
Smile Got the AUX running.
In the Mercedes-Benz Adarsa workshop (Asturias Spain), they did not know that these hidden menus existed. The astonishment was great.
Now the AUX works.
Once again, thank you so much.
Old Dec 21, 2021 | 02:56 PM
BOTUS's Avatar
S500
if there are impressed with that - they ought to really happy I added two missing comand unit models to the clock update CD
Old Jan 27, 2024 | 02:54 PM
er_goro's Avatar
w221
Now the AUX works.
Hi, I have a Limcet box 5501. It works ok, when I put the option aux it sound, my problem is that I dont know how I can use the OEM microphone. I selected the option in the box, but it doesnt work, any knos how I can activate it? thanks
