Hi family, I'm asking for advice on a COMAND update. thanks in advance greetings to
Old Feb 20, 2022 | 07:40 AM
Oderfla's Avatar
mercedes s 500 w221 año 2005
Hello very good to this great family. I'm here asking for advice on a command update issue. I have Xentry/DAS 07-2016 with offline programming and working great. Now the following happens to me. …when I connect the XENTRY/DAS to the car and do a diagnosis there is only one error and it is in COMAND. the error puts code..DFFF COMAND SOFTWARE IS NOT CURRENT... now I hit offline programming and I get to the page where it tells me that there is a new version for the radio tuner and asks me to update with some of the following... TELEMATIC CD. 2168274159…2218270065…2218270465…2218270665…first question which of them is the one I have to use???? say that my car s500 w221 end of 2005 European version and I have a bird's eye view in the COMAND. real time traffic and video option from what I understand it has one of the latest Telematic updates. the COMAND works perfectly, the only thing that is true is that the radio does not tune the stations very well. And just this update tells me that it corrects errors in the radio tuner hence wanting to update and apart from the fact that the update lasts 8 minutes. Say I have a 20A battery charger. It also takes longer to update the navigation maps to 2019 almost 45 minutes and the clock correction almost 15 minutes and everything is great. so what telematic cd should i use???? What if this update killed the air conditioning? I read something about it. I thank you very much in advance for all your help. A very strong greeting from Spain. to take good care of yourself.
Old Feb 20, 2022 | 08:28 AM
BOTUS's Avatar
S500
there's a post where someone did this
https://mbworld.org/forums/s-class-w...pdate-diy.html
Old Feb 20, 2022 | 03:16 PM
Oderfla's Avatar
Hello BOTUS.
Thanks BOTUS for the link. she had already read it several times. I have read it again. what happens is that this link refers to a telematic update. of COMAND completes which lasts a long time. this update was done to my car in 2008 and it was the one that gave it all these bird visit functions. real-time traffic. video option etc so far good. what I don't know what telematic gave all these functions to my car. That is why I have asked which telematic of those that I put in the first message I should use. I understand that the 216 should not be. So I still have to know between these three which one I should put if 2218270065..2218270465..2218270665.. I have looked in Xentry/Das in COMAND the version that I have but I am not clear which cd telematic. it was put in his day to my car. I attach a photo. I have this question of which one to use for this small update that Das asks me to do. update that only lasts 8 minutes and that is for the TUNER SOUND CONTROL UNIT. in DAS it puts programming time 8 minutes. It also states that with this new software the following errors are solved. RADIO/Poor reception. RADIO/RDS regional programs function error. AUDIO/Disturbance noise emitted from the speakers. AUDIO/Poor audio quality. RADIO/Poor sound quality. Of all these errors, the one I have is from the radio. POOR RECEPTION. hence why you want to do this update. but of course I need to know what telematic to use. and the other most important question is little update for the radio tuner WILL IT TURN OFF MY A/C ???? once again a million thanks. Thank you very much to all of you for your help.
Old Feb 20, 2022 | 05:31 PM
BOTUS's Avatar
S500
never heard of reception issues in the W221
on most other Mercedes its the antenna amp has either bad connections or its just failed - there is an antenna amp just above the top centre of the rear window - crazy money
the OTHER optional tuner DAB for Europe and US Satellite radio both use a separate tuner and it might have an update in USA (no idea?)
I don't think the comand system will make the radio play different.. the picture you have above shows the same software I have on my comand unit - Mine was updated to those by Main Merc dealer in Oct 2014
Old Feb 20, 2022 | 05:42 PM
Oderfla's Avatar
Botus
thanks again for your response BOTUS. then you advise me to leave it like that and not update??? or can i do this update. what would you do in my case?
Old Feb 21, 2022 | 01:47 PM
BOTUS's Avatar
S500
It would give you what's there... but at risk you damaged it (so leave alone)
and if you updated the clock, mess that up again (although that's an easy fix in 10mins with a CD you make yourself)
Old Feb 21, 2022 | 03:59 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
I think in an early W221 like my 2007 S600, once you have COMMAND updated to 3.5 which is the birds eye view; you can't go to COMMAND 4.0. So if you already have bird's eye, call it a day.
As far as other updates, BOTUS has weighed in on many of the other questionable feature upgrades to radar, braking, and a few other settings. He is by far one of the more discerning and knowledgeable contributors here.
Old Feb 22, 2022 | 01:02 AM
Oderfla's Avatar
Hello
Thanks for the answers. I will follow your advice and leave it as it is. . once again thank you for your help. a strong greeting greetings from Spain
Old Feb 22, 2022 | 11:49 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
The latest software version is: 0024427760,2214424360 (USA Car)
Your softtware version is: 0014427060,2214424360
Old Feb 22, 2022 | 12:43 PM
Oderfla's Avatar
Hello friend
thanks for the info mate. I thank you very much for your answer. that's why XENTRY/DAS tells me that there is a new software for the TUNER SOUND CONTROL UNIT. programming duration 8 minutes. once again thanks for the information. a greeting from Spain.
Old Feb 22, 2022 | 02:07 PM
BOTUS's Avatar
S500
tuner software isn't the comand software... ones by your knee the others in the boot, it can be done separately - but its is programmed by a CD in the comand unit - you have to set the car up in Xentry then it tells you which CD to install - the factory method then double checks the disc you fitted was the one it said to use, and loads via the most to the tuner in the boot in about 20 minutes
the correct disc for a UK Tuner to software sw 2219027901 either of these cd's 2168274159 or 2218270065
Old Feb 22, 2022 | 02:57 PM
Oderfla's Avatar
Hello BOTUS
Gracias BOTUS por tu respuesta. la nueva actualización que me dice XENTRY/DAS que está disponible en mi auto es para el SINTONIZADOR DE SONIDO. y me pide que inserte uno de los siguientes CDs 216827459…2218270065…2218270665. esta programación según Xentry/Das dura 8 minutos. Por eso preguntaba que cd poner ya que tengo los tres CD en mi casa, esa era una de mis dudas cual debo usar.??? y la otra duda que tenia era que si hacer esta pequeña actualización podria estropear algo???? . No me gusta hacerle nada al coche sin antes leer mucho sobre el trabajo que quiero hacer y, sobre todo, preguntar a expertos como tú. por eso hice la pregunta si debería hacer esta actualización de software que está disponible para mi automóvil. una vez más estoy muy muy agradecido con usted y los demás compañeros por toda la ayuda y toda la información que me dan. Todos los días aprendo mucho con todos ustedes. Gracias saludo desde España.
Old Aug 31, 2023 | 05:09 PM
mynits's Avatar
W216 W140
Did i right understand you,that 2168274159 and 2218270065 are same?
Old Sep 1, 2023 | 04:53 AM
BOTUS's Avatar
S500
not quite - although Merc says they are directly compatible - when you check the discs they have tiny differences, some head units are on one disc and not the other - NEVER believe Mercedes know what they are doing - the CL models are meant to use 2168274159
An S class in europe should use 2218270065 - you need to re-enable the AC after flashing this HIFI unit !!!!
Only USA should insert
2218270665
you should read this LONG thread
Old Sep 3, 2023 | 02:47 PM
mynits's Avatar
W216 W140
Ty for advice,i think its will be on old firmware
Old Sep 3, 2023 | 04:23 PM
BOTUS's Avatar
S500
check the clock fix post
there is a number in hidden menus.... 421 or earlier its out of date, 422 current, 423 has the clock fix re WNRO Apr 2019
was covered last week too
https://mbworld.org/forums/s-class-w...ml#post8834525
Old Sep 3, 2023 | 04:31 PM
BOTUS's Avatar
S500
I guess u know about these sites ? gives an idea of what they built it with
FIN WDD2163771A006074
Model CL 63 AMG
Engine 156984 60 010994
Transmission 722907 01 103891
Order Number 0 7 526 01111
Order Location UKRAINE
Production Number 7906129
Interior EXCLUSIVE LEATHER - BROWN (504A)
Paint 1 OBSIDIAN BLACK (197U)
Release Date 2007-02-21
Delivery Date 2007-03-09
Code Description
197U OBSIDIAN BLACK
203B OWNERS MANUAL AND SERVICE RECORD - RUSSIAN
218 REAR-VIEW CAMERA
229 PARK ASSIST
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
264B AIRBAGLABLE - RUSSIAN/ENGLISH
289 LEATHER STEERING WHEEL WITH TRIM INSERT
301 ASHTRAY PACKAGE
310 DUAL CUP HOLDER
364B BATTERY LABEL - RUSSIAN
388 PHONE MOBILE, MTUS-SYSTEM
401 FRONT SEAT CLIMATE CONTROL
427 AUTOMATIC TRANSMISSION 7-SPEED
432 DYNAMICS SEAT,FRONT LEFT AND RIGHT
435 HEAD RESTRAINTS,REAR, PNEUMAT.FOLDING UP/DOWN
443 HEATED STEERING WHEEL
477 TIRE PRESSURE LOSS WARNER
500A EXCLUSIVE LEATHER TRIM
504A EXCLUSIVE LEATHER - BROWN
524 VEHICLE PROTECTIVE COVER (FULL BODY COVER)
526L UKRAINE
527 COMAND DVD APS WITH NAVIGATION
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 BASIC ANTITHEFT ALARM SYSTEM (ATA)
581 AUTOMATIC CLIMATE CONTROL
5XXL EUROPE
610 NIGHT VIEW ASSIST
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
619 CORNERING ILLUMINATION
668 PRODUCT PROT. F FREIGHT PACKAG. W TIE-DOWN HOOKS
673 HIGH-CAPACITY BATTERY
682 FIRE EXTINGUISHER
690 EMERGENCY SPARE TIRE (MINI SPARE)
736 TRIM PIECES - ASH TREE WOOD BLACK (2A70)
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
788 19" AMG MULTI-SPOKE WHEELS W/ MIXED TIRES
807 YEAR OF MODIFICATION
810 PREMIUM SOUND SYSTEM
814 DVD CHANGER
863 TV-TUNER DIGITAL TO ANALOG
875 HEATED SCREEN WASH SYSTEM
876 INTERIOR LIGHT ASSEMBLY
881 REMOTE TRUNK LOCKING
882 SENSOR SYSTEM AND ANTITHEFT ALARM SYSTEM
889 KEYLESS - GO
89V SPEED- + LOADINDEX ZR19 XL+ZR19 XL
910 DYNAMO WITH HIGHER CAPACITY (FFO)
983 COC PAPER EURO 4 TECHNOLOGY W/O REG. CERT. PART II
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A46 P-SHIFT PLATE WITH VGS2
F216 MODEL SERIES 216
FC COUPE
G907 TRANSMISSION CODE VERSION 07
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K12 STEUERCODE FUER SERVICEINTERVALL 30000 KM
K15 CONTROL CODE FOR SERVICE INTERVAL 15000 KM
L LEFT-HAND STEERING
M156 V8 GASOLINE ENGINE M156 - AMG
M63 6.3 LITER DISPLACEMENT
R01 SUMMER TIRES
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
U75 DVD PLAYER W/ REG. CODE 5, RUSSIA, EASTERN EUROPE
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
Mercedes Benz VIN decoded at https://www.lastvin.com/vin/7l9rK2eYPk62bZeLm
Old Sep 4, 2023 | 02:14 AM
mynits's Avatar
W216 W140
Yeah,i know about lastvin
But what you meean for decoding vin?
Old Sep 4, 2023 | 02:34 AM
mynits's Avatar
W216 W140
Old Sep 4, 2023 | 05:05 AM
BOTUS's Avatar
S500
the other bit to check if its had the BIG update.... in the user menus on the comand go to Navi - Maps and Map view if it has the option for "Bird's-eye view" it got the big update - there was later in late 09 43 (2009 week 43) another update for the Tuner only - no idea what it did
middle pic of those 3 is the hardware date (not software) - go to the car with dealer tools ... do quick scan then press F8 it will list ALL modules and hardware and software status, if it list 9 million faults don't print it (will waste paper) clear all the lies and start again then you get just 7 pages of what the state the cars software is in - no one ever updates them....
you certainly haven't fixed the clock yet !!!
Old Sep 13, 2023 | 01:48 AM
johnnyrocket52's Avatar
2009 S600 V-12
Hi Guys,
2009 S600 and my analog clock is reading the correct time and I found the Birds eye view feature in my nav.
Am I up to date with these two items.
Is there a menu I can get the current clock and Nav software versions.
Last question, what the latest year of maps for a 2009?
Bird’s eye View
Old Sep 13, 2023 | 05:37 AM
BOTUS's Avatar
S500
usa quite incredibly has more miles of roads than the 45 countries that makes up the majority of europe - something like 500k vs 450k and I wonder if they decided with five million gig of useless points of interest no one has ever used on any sat nav, if they felt the latest data no longer fitted on the disc - certainly on the later head unit they gave up new mapping for USA in 2015
re is it up to date - I'd go in the secret menu and check for 423 - a car that hasn't has the battery left off it can still fake the year... but the month tends to go random and slowly the analogue clock will go out of step
get in the car and turn on the key (it can ALL be done with it running - they flatten batteries in seconds on these cars otherwise)...
move the comand cursor (which Icon is highlighted) on the top menu bar that reads Navi, Audio, Telephone, Video, Vehicle,
use the control wheel to select Vehicle. Then pull the control wheel to the bottom menu and highlight System Settings
now these four all have to be done together
o Press and hold the “*” button, which is referred to as the “Favorite” button and typically actuates the rear sunshade.
o While holding “*”, press the Control Dial to the Right without pressing it down or turning it.
o While the “*” is pressed and the Control Dial is held to the right, press the Seat Massage button to the right of the Hazard switch and hold it.
o While holding the “*” button, the Control Dial to the Right, and the Seat Massage button, press the Mute button, which is the button located below the VOL dial and has an icon with a speaker with a slash though it.
 When this combination is performed successfully, you will have reached the Engineering Menu.
change NOTHING other than instigating update if you have loaded the right clock fix CD in the drive - but you can safely scroll round to look at everything
if its not on version 423 if the battery has been disconnected between Nov 2019 and now, it may well say year 2003 together with random time and day / month issues - and if in a daylight saving area - the time will be random and out of sync with the analogue clock regardless of battery disconnection
Old Sep 15, 2023 | 01:37 AM
2009 S600 V-12
Thanks Botus, I’ll log into the secret menus and report back on firmware version.
I will only look.
Old Sep 15, 2023 | 07:26 AM
BOTUS's Avatar
S500
on these early NTG3.0 cars they didn't build in any security to stop you borrowing a mates new maps DVD... it reads and writes it to a hardrive, then you take the disc out and its effectively bin material - thus its very easy to get hold of them...
on a 2006 car it will clunk and whirr and say failed and split the disc out (that's normal) you press it back in again and say sure it is - it says OK, do you want to update (about 45 mins with the engine running !) - over the next few weeks in my experience (done mine 3 times for new maps) often on start up the unit will pop up a message saying Nav not ready, then get over itself within a min or two - over the course of a month it settles down and goes away for good (I believe its really transferring the info to the correct part of the harddrive)
on 2008 cars the menu reads a more alarming world ending message - and you just say sure kill the unit then and it loads the new maps (43 mins is normal for the 2019 european maps)
on NTG3.5 late 2009 cars, it needs a pin number linked with chassis number to unlock loading the newer mapping info
Old Sep 18, 2023 | 02:11 AM
2009 S600 V-12
Hi Botus, I was able to access the Top Secret Engineering Menus.
It showed 422 in the upper right hand corner, meaning it doesn’t have the clock fix?
To complete the clock fix it needs to have the DVD functioning to load the patch to bring it up to 423?
If yes, then next step is to get DVD repaired for $300…
JR
