Right front door window, help urgent needed.
Old Apr 21, 2022 | 06:16 AM
Timo Schroeder's Avatar
Class S 500 M278
Help urgently needed. Right front door window. My Gardner have just destroyed the right front door window glass. And I'm now struggling to get a new on. As far I can understand there are several different types of the glass, with different numbers. Also different numbers for the same type double glass. Who to find out the right type?
There are obviously minimum two different types/numbers A2217201618 and A2217200818 both double layer of glass, what's the difference besides the numbers ?
According to the win number this is the glass fixed in my car; 596 HEAT INSULATING+IR REFLECTG.SAFETY GLASS ALL-ROUND
Vin number WDD2211941A398659
Old Apr 21, 2022 | 06:24 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Where do you plan to source it from? If from MB, just give them your VIN, and let them figure it out. If you buy from certain sellers on Ebay, they may be able to do that for you as well. How was it destroyed? BTW, do any of you have some discoloration at the top of the laminate between the glass?
Old Apr 21, 2022 | 06:29 AM
Class S 500 M278
Thanks for your fast response. I looking to buy a good used one. It was destroyed by a flying small stone from a lawnmower. See pictures.
Old Apr 21, 2022 | 07:21 AM
Senecat's Avatar
1983 Nissan Shltbox
Post your vin
Old Apr 21, 2022 | 07:45 AM
Class S 500 M278
Originally Posted by Senecat
Post your vin
Old Apr 21, 2022 | 11:36 AM
konigstiger's Avatar
'71 Pinto
File Type: pdf
File Type: pdf
Old Apr 21, 2022 | 12:45 PM
E55Greasemonkey's Avatar
This place is a joke.
Note the writing on the lower corner of the glass and match it to a used glass.
Old Apr 21, 2022 | 12:54 PM
Class S 500 M278
Thanks for your reply. I have found a new Used window, right front door, double layer but the number are A2217201618 - can I use that or just forget everything about it. Good day.
This is the current window.
Old Apr 21, 2022 | 12:59 PM
Class S 500 M278
The numbers on the current window, doesn't make any sense to what I can read there.
Old Apr 21, 2022 | 01:09 PM
'71 Pinto
Shows compatible 885 enhanced security is roof mounted motion sensor should not matter.
Old Apr 21, 2022 | 01:28 PM
Class S 500 M278
Thanks for your help. So can I use the window I've found in my car ?
