2009 W221 S550 acting very weird
Old Jul 25, 2022 | 01:52 PM
yhilmi2010's Avatar
W221 2009 S550
Hi all,
First of all, I want to thank you in advance for your help with this matter. I have recently purchased a 2009 S550 from an older gentleman with 82k miles on it. The car had only 1 pervious owner and has an excellent maintenance record.
The problem I am having is that the car started the run erratically all of a sudden. I was driving yesterday and suddenly the car started to misfire and slightly accelerate on its own, then the CEL came on. So I pulled over and noticed that the car revs un-commanded to around 2000 rpms. However, it shifts fine through the gears and responds normally to the brakes. I managed to drive the car home and ran a quick diagnostic and found 5 codes related to the CEL, which two of them indicated O2 sensor Bank 1 and Bank 2 Sensor 1. The icarsoft OBD2 I have was not able to read the other 3 codes. I also ran a manual diagnostic and found a series of current codes including the followings:
-1337
-0217
-1061
-0600
-2313
-6264
-2A23
-9005
-9001
I have cleared the CEL codes and reset the ECU and the car is now running just fine. I wanted to check with you and see if anyone has encountered this in the past or has any idea what this might be. Maybe it is a control unit issue? I have have had a 'Control Unit Performance' CEL light come up in the past along with I believe a 'Control Unit Low voltage' message (I cannot recall the exact message but it was voltage related). Could this be a bad battery? The battery was last replaced in December 2020 at a Mercedes dealership and the brand is DieHard.
Any help with this will be greatly appreciated.
Old Jul 25, 2022 | 03:25 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Bad gas?
Old Jul 25, 2022 | 03:54 PM
yhilmi2010's Avatar
W221 2009 S550
Originally Posted by kevm14
Bad gas?
Thanks for the reply! If it was due to bad gas, I am assuming the issue will come back but I have driven the car today without issues. I use 93 octane from the same gas station for years and never had a bad gas issue. I am thinking this is related to electronics as the car started acting normal immediately after resetting the ECU reset.
Old Jul 25, 2022 | 03:57 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
It does sound like bad gas or maybe a dirty fuel filter. I would also run a can of fuel cleaner through it. If any of the codes return, keep us posted. With all of those strange codes you listed; it is very hard to pinpoint the problem.
kevm14's Avatar
Well it could still have slurped up some water. Run tank down and refill or try some dry gas stuff if it happens again.
Old Jul 25, 2022 | 04:13 PM
yhilmi2010's Avatar
W221 2009 S550
@kevm14 and @vettebk , thank you both!
I will do that. What brand of fuel cleaner do you guys recommend? And I will definitely keep you posted on what happens next and will make sure to document everything. Thanks again.
Old Jul 25, 2022 | 05:21 PM
vettebk's Avatar
I use a 20 oz plastic bottle of Techron every other month on the first of the month. To get the best effects, I wait until the fuel tank is less than 1/4, add the Techron, drive it to the gas station (about 5 miles) and fill it up with 93 octane. Everyone always tells me additives are B.S., but a number of us have had really good results. I buy Techron by the case of six on Amazon.
Keep us posted on the news.
Old Jul 25, 2022 | 06:21 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CEL + Codes
Originally Posted by yhilmi2010
Hi all,
-1337
-0217
-1061
-0600
-2313
-6264
-2A23
-9005
-9001
something is causing your ECU to act up. At the time O2 sensor were flagged the ECU was struggling to keep the engine running. I think it's safe to say your O2 have another 40kMi life left.
Can you translate your list of fault codes?
This driveability issue seems related to fuel :
  • fuel pump,
  • fuel pressure,
  • fuel filter,
  • pressure regulation,
  • saddle pump.
Try to rule out marginal voltage as well.
Old Jul 26, 2022 | 11:40 AM
yhilmi2010's Avatar
W221 2009 S550
I will try this and report back if the problem persists. Thank you so much!
Old Jul 26, 2022 | 11:46 AM
yhilmi2010's Avatar
W221 2009 S550
@CaliBenzDriver Thank you so much for your reply. Unfortunately, I have deleted the list of codes (my error). I am going to run a fuel cleaner and see if the drivability issue persists. If yes, I will report back and make sure to document the codes properly next time. Thanks again!
