Mercedes w221 s350cdi no crank
Get yourself a scanner, a Xentry computer or an apt with your local expert.
This will be helpful to crawl out of this nightmare without blindly replacing too many pricy parts.
> Your #1 issue right now with this NO CRANK is the IGNITION SWITCH fault.
Take the switch out, open it to show the inside for solderless electronics... maybe fixable in 10mn for 2¢
> STOP SWAPPING PARTS!
We are not dealing with a laundry machine
!!Computer + transmission+ ignition modules are all closely matched together to prevent theft. You may end up triggering the car security by using unmatched parts... don't swap or your car is guaranteed to need a Ninja's expert attention.
> Do not let the battery voltage run low.
This helps glitches soft-crash modules into crazy states that require massage. Plug a charger ir power source if you can't run the engine.
Hopefully this will be over shortly... like a painful visit to the dentist
[/QUOTEThank you for responding 💪 I will try with the ignition, i hope se 2 months i have this nightmare 🙄
