I have had it..... Click noise when car in motion from front wheels
Old Sep 16, 2022 | 07:33 PM
al300sd's Avatar
83 300sd, 88 560sl, 14 e550
I have had it..... Click noise while driving solved ( broken motor mounts jigiling)
2008 4matic s550 , Fixed Blower, installed relay, for Amp (thank you all for your input!)
Took it out on a trip with fam and was left stranded at night after dinner an hour from home (starter).
Here Goes. I went to change the starter in a rush with little sleep..
started jacking the car from the front cross member... Jack slipped and went through the shield and caught the crank pully.
the motor mounts snapped but other than that no visible damage.
Changed starter, fired up drove a few feet and ESP error popped up.
checked sensor and its though the wheel is straight the angle sensor is reading 80 degrees tried to reset etc did not work now car displays esp abr abs.... "diagnostic mode"
drove ok otherwise.
tried to perform the reset to get out of "diagnostic mode" did not work and after it sounded like i had a playing card stuck in the wheel the faster i went the louder it gets.
Jacked up the front end and spun the front wheels and its making that tapping clicking noise... WTF is it.....
apologies but this car is getting to me ...
ill post some pics and video tomorrow..
Old Sep 17, 2022 | 07:44 AM
BOTUS's Avatar
S500
4x4 or rear drive?
dropping off a jack till the engine mounts give up - doesn't sound good - I can imagine various wiring looms felt the strain
if its rear drive there isn't really very much going on re the front wheels - they go round - and if something is snagging on the tyre, rim or disc it could make noises
if its 4x4 did it fall on to the drive shaft and make a CV joint or trans box complain ?
Old Sep 17, 2022 | 08:26 AM
al300sd's Avatar
Originally Posted by BOTUS
4x4 or rear drive?
​​​​​​ it a 4matic, when a jack slip the wheels were still on. And it drove fine for about a day.
Old Sep 17, 2022 | 10:13 AM
al300sd's Avatar
4x4 or rear drive?
Sooo it was a chunk of the motor mount rubbing on axle boot.
no how do i get this stupid heat shield off the motor mount....
Old Sep 17, 2022 | 11:05 AM
konigstiger's Avatar
'71 Pinto
Front left & right 2212400817 or MB direct 221240081764, rear 2212400518, see attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 17, 2022 | 12:06 PM
al300sd's Avatar
Is there an easier way where I can take less things apart?
Can I jack underneath the transfer case?
Old Sep 17, 2022 | 01:10 PM
BOTUS's Avatar
S500
lifting the weight of the engine, half the gearbox and the transcase with a jack is not a good idea... if the bolt is accessible on the top of the engine mount - as per the first PDF (the bolt that comes out going up) and you carefully spread the load with a block of wood and something soft in between, can u ease things up to get clearance to whatever it is you need to reach - bit confused it shows a massive hole - I guess for the drive shaft to go through - if that's not where it should be something is still not fixed on mounts and or location of various parts?
you get one set of fingers and one life.... everything else can wait till its done safely
Old Sep 17, 2022 | 01:53 PM
al300sd's Avatar
Well naturally I would put a piece of wood under the Jack and try to lift it from the front. Are you saying that you can't do that and the only way to do it is to get an engine hoist?
Old Sep 17, 2022 | 02:40 PM
BOTUS's Avatar
S500
I'm saying its not a good idea - go careful - it will be heavy and it was only meant to keep the oil inside, not becoming a jacking point
Old Sep 17, 2022 | 07:18 PM
al300sd's Avatar
The clicking culprit....
Old Sep 18, 2022 | 01:35 AM
Senecat's Avatar
1983 Nissan Shltbox
Good job. Now stop damaging your car.
Old Sep 18, 2022 | 04:48 AM
BOTUS's Avatar
S500
I was thinking - if you watch vice grip garage Derek and his wife both throw jacks under old GM cars and trucks without looking, jacking up on a guess at the front cross member (because its massive and always in the same place)
this is not something anyone should do on the vast majority of European car's made in the last 40 years (even if you look at where you are placing the jack) - there is no substantial structure front or rear to jack up both sides in one go - its a huge no no.
they are ONLY designed to be picked up with an appropriate vehicle ramp or corner by corner on the 4 jacking points along the structural sill
at the back on a rear drive the diff is not attached to the car in any way you should consider using as a jacking point EVER and on front drive there is NOTHING you should put a jack near in the middle
Old Sep 18, 2022 | 11:06 AM
BOTUS's Avatar
S500
please enlighten me - what the hell are all those bits ?????
Old Sep 18, 2022 | 04:57 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
lol, I love that.
Also, from what I recall there is a jack point in the front of my W211 and W221. I use my Quick Jack for most things these days though.
Old Sep 20, 2022 | 09:21 AM
al300sd's Avatar
that is the bottom half of the motor mounts...
