Thinking about going nuclear--coilover from ABC
Getting off to this bad start of not even being able to release my first line, I'm wondering if I should dump ABC. Anyone else done this? I'm aware of Strutmaster and Titan for replacement. Titan is adjustable which is nice. I'm concerned about the car's stability (and safety?) without a sway bar--can one be installed if I switch the control arms to the W221 type?
Any general thoughts will be appreciated.
In my opinion, I would not do it. You WILL need a sway bar from a non ABC S class and this issue is covered by the YT video.
My experience with ABC is good when I do the proper maintenance. It is expensive only when I don't do the proper flush, filter, accumulator and hose maintenance/replacement.
Let us know what you decide to do. Tough decision to make.
intransitive verb
To swing back and forth
cars don't do that, they lean about an axis - AKA they roll, the ARB's job is to control the rate that roll accelerates and to resist it... hence
anti / æn.t̬i
adjective, preposition
opposed to or against a particular thing
does this answer the thread this week - my suspension has gone solid... https://mbworld.org/forums/s-class-w...uspension.html
intransitive verb
anti / æn.t̬i
