I am having a random issue with my driver’s side mirror cover led turn signal. For some reason the led turn signal does light up but also it doesn’t cause an error message on my cluster.. anyone ever have this issue? Is there a fuse for this?I also need to know the part number to mount turn signal lamp to the mirror cover since the prior owner decided to not put them back. The screws with the red circle around is what I need a part # to
If you're desperate, go to the hardware store with the new turnsignal and find some screws that fit the hole.
If they're too long you could shorten them yourself.
Get some rings too.
