W221 headlight retrofit with OEM SAM - 2024
Old Nov 10, 2024 | 03:18 PM
Plato's Avatar
W221 S500
Hi!
Back to 2010 in the time of 221...
With reference to this thread I am looking if someone who has bought MBSCA (https://www.ckmcardes********/s-clas...sen-adapterkit) or SonicMS wiring harness with magic black box on that time. Since there are plenty of plug-n-play solutions these days I was wondering if someone has these items in used condition for sale or who can share installation manual and schematic diagram to make it myself. Or if you know any other solution kindly asking to share it with me please. I would pay for a working solution in PM. Below you can find what is going on and what doesn't work.
Long story short:
I have 2008 W221 with 2012 headlights + 2012 SAMF + Magic CAN module to support adaptive light functions. In this combination all light functions were woking properly including DLR, cornering lights, left/right lens rotation, adaptive anti-fog light and all other functions of the original headlights. But non original 2012 SAMF cause a lot of problems to the rest of the car and most important is incorrect batteries management since 2008 and 2012 has completely different batteries in different locations (35Ah vs 95Ah AGM under the hood, 95Ah AGM vs none in the trunk, and none vs ~10Ah in the dashboard).
I was informed by the manufacturer of the CAN module that it was originally designed to work with OEM SAMF so I decided to change it back to original SAMF. Found the correct one in EPC. After all adaptive light functions are woking properly. Low/high beam, night vision, turn signals are ok.
But these doesn't work:
1. DLR: I have changed pinout in SAM from fog light to DLR. They works but not correctly. They work on 100% power and only with headlights. Normal behaviour should be: Work on 100% power without any other lights on daytime and ~60% power with headlights at night. Changing brightness in SCN coding in SAMF does not affect it.
2. Parking / staying lights - doesn't work at all.
You help will be much appreciated.
Old Nov 10, 2024 | 03:29 PM
BOTUS's Avatar
S500
I thought you need the later CGW then update whatever it is / code the features, then refit the orig CGW - never heard anyone use a SAM to try and get the job done
Old Nov 10, 2024 | 03:32 PM
Plato's Avatar
W221 S500
I actually don't know what CGW I have and if it was changed but the previous owner on the time when he changed SAM.
But according to the thread mentioned above changing SAM and CGW was only 1 out of 3 options.
Old Nov 10, 2024 | 03:37 PM
trigital's Avatar
W213 All-terrain
I made hundreds of headlights retrofit on w221.
Only need facelift SAM ( the one with plastic cover) and the wiring accordingly with the facelift schematics, no any adapters needed.
All functions works, ILS, DRL, even the Battery management can be coded.
There are several wires that need to be added and most of them need to be re-routed on SAM side.to have the facelift configuration.
Old Nov 10, 2024 | 04:23 PM
Plato's Avatar
W221 S500
But how to get that work with original SAM since I have CAN module for adaptive light.
Old Nov 10, 2024 | 04:26 PM
BOTUS's Avatar
S500
what do you mean by adaptive light ? auto high beam ?
half the stuff in in the cluster is it not?
Old Nov 10, 2024 | 04:30 PM
Plato's Avatar
W221 S500
By adaptive I mean Cornering Lights, Intelligent Light Spread System, Integrated Curve Illumination, Head Lamp Range Adjustment, ActiveFogLight, HighWayMode, etc.
By basic functions I mean headlight (low/high beam), turn signals, night vision, parking/staying lights, DLR.
I have everything listed above currently working on original 2009 SAM except DLR and parking/staying lights.
Old Nov 10, 2024 | 05:10 PM
BOTUS's Avatar
S500
Intelligent Light Spread System - not sure how you get this with xenon lights on a 221 ???
Old Nov 10, 2024 | 05:43 PM
trigital's Avatar
W213 All-terrain
DRL, Fog, Cornering, curve light, etc are functions inside the ILS.
Maybe the IHC ( Intelligent High beam Control) could be a problem, I don't remember as when I did those retrofit the IHC was not so popular on w221.
For doing all that, only need to install facelift SAM and do the wiring. No adaptor is needed.
With original non-facelift SAM none of those functions will work. I have no experience using the CAN adaptor.
Old Nov 10, 2024 | 05:46 PM
Plato's Avatar
W221 S500
With a special CAN module. It works with both old and new SAM
Old Nov 10, 2024 | 05:52 PM
trigital's Avatar
W213 All-terrain
Maybe the "special CAN module" is only needed to bridge the camera signals for enabling the IHC. The old SAM can't do ILS nor DRL.
Old Nov 10, 2024 | 05:54 PM
Plato's Avatar
W221 S500
No, this CAN module does full ILS available on 2008. It doesn't add new features but restore those available in original headlights.
Old Nov 10, 2024 | 05:55 PM
Plato's Avatar
W221 S500
My current problem is not ILS since it works. I have issues with DLR and staying/parking lights.
Old Nov 10, 2024 | 05:56 PM
Plato's Avatar
W221 S500
However I have SCN settings to choose if I have fog lights or DLR in my SAM. The SAM number is exact what EPC shows.
Old Nov 10, 2024 | 05:58 PM
trigital's Avatar
W213 All-terrain
Being a non-facelift car, if the SAM has the reference number showed by EPC, means that the SAM is not facelift.
Old Nov 10, 2024 | 05:59 PM
Plato's Avatar
W221 S500
Yes exactly but still it has option to enable/disable DLR
Old Nov 10, 2024 | 06:02 PM
Plato's Avatar
W221 S500
Before installing a CAN module I had a facelift SAM but ILS functions didn't work. A facelift SAM only enable basic functions I believe. Later I have installed CAN module and everything started to work properly all functions. But as I mentioned before I decided to revert to old SAM. Now everything works beside two things above.
PS: IHC cannot be activated since it require a facelift camera and windshield.
trigital's Avatar
W213 All-terrain
Indeed, but is referring to h7 DRL or to main beam as DRL ( in 2007 DRL was h7 in the bumper near the h7 fog light or with main beam)
P.S. DRL - Day time Running Lights
Old Nov 10, 2024 | 06:03 PM
Plato's Avatar
W221 S500
IC thanks for clarifying that.
trigital's Avatar
W213 All-terrain
Wrong decision....
If you want, I can help you to enable everything if you are willing to read my messages and to re-route wires
Old Nov 10, 2024 | 06:11 PM
Plato's Avatar
W221 S500
Wrong decision....
Of you want, I can help you to enable everything of you are willing to read my messages and to re-route wires
I just want my SAM does it's job properly. There is too much to re-code to make it proper work with batteries and all other dozens of devices/features. With old SAM you only need to work around headlights.
I of course will do everything you say, thanks for trying to help me. But first please check below pinout. It's for the left side. The right one done the same way.
PS: I was looking for diagram of this solution: kmcardesign[dot]com/s-class/w221-06/klarglas-faclift-framlsen-adapterkit
The prise was extremely high but W221 is old now so was looking if someone could share it... According to the picture there is some box and resistors (probably used for parking lamps). Was curious what's inside black box and how it all was connected.
Old Nov 10, 2024 | 06:22 PM
Plato's Avatar
W221 S500
My guess is parking lights could be fixed with resistors and for DLR a coding is required... Maybe I am wrong
trigital's Avatar
W213 All-terrain
For me, to add 2 wires and to re-route some on the SAM side accordingly to the Mercedes W221 facelift schematics is the correct way of doing a retrofit. Coding is also something simple and safe than using resistors.
Sorry, I am a trained technician at MB and my experience is limited to WIS schematics,
Old Nov 10, 2024 | 06:24 PM
Plato's Avatar
W221 S500
I was trying to say that it's most likely already done (wiring). I have 2 extra cables going from SAM to headlights.
Could you please send me instructions inc coding so I can check if it's done. If it's not done yet on the car I will do it.
Old Nov 10, 2024 | 06:28 PM
trigital's Avatar
W213 All-terrain
Of course, I can post here schematics for facelift headlights, but this schematics will work with the facelift SAM ...without adaptor if adaptor is not only for IHC. Do you have any link for your adaptor?
