2008 S63 standard sunroof sinking in rear
Old Sep 16, 2025 | 09:31 AM
Rocco Russo's Avatar
Hey guys,
Just picked up a 2008 S63 AMG with a standard sunroof (non-panoramic).
It all functions normally, however when in fully closed position the rear sinks in. I can correct it by manually raising the tilt slightly, so that it sits flush with the roof, but I do not want to continue relying on this method and want to resolve the issue.
I attempted to search this forum and google for some answers before making this post, however most of the results were for panoramic roof issues.
Any ideas? Anyone with similar past experience?
Old Sep 16, 2025 | 10:11 AM
AL5461's Avatar
W221 S500
Had this on a 1 series coupe following a sunroof cassette replacement. Turns out the coupe and hatch roofs are a different shape and use different settings.
If you've had recent work done or the batteries have been off for a while, be worth double checking the coding in the roof motor/OCP as LWB/SWB/CL may well have different position settings. You may even find something in WIS for adjusting the closed position.
It could even be as simple as normalizing the motor. DAS/Xentry can guide you through this. Any codes in the OCP?
Old Sep 16, 2025 | 10:34 AM
Appreciate the quick reply, unfortunately I do not have DAS/Xentry although I am looking into getting it. If I’m being honest it’s all a bit overwhelming with the multiplexers and different software versions, etc.
I will have someone with the software look into it, and report back with any findings or hopefully resolution.
Old Sep 16, 2025 | 03:26 PM
TimC300's Avatar
Can always try synchronizing it.
Old Sep 16, 2025 | 08:02 PM
Alexie's Avatar
Originally Posted by Rocco Russo
Hey guys,
Try resetting it. Hold the tilt button up until the roof completes a full open/close cycle and keep holding it for another 10 seconds after it closes. If that doesn't fix it, the cables are probably stretched and need professional adjustment.
Old Sep 17, 2025 | 12:12 PM
Much appreciated guys, going to try the reset.
Old Sep 17, 2025 | 02:00 PM
AL5461's Avatar
W221 S500
Where abouts are you located?
Old Sep 17, 2025 | 03:20 PM
Long Island, NY
Old Sep 18, 2025 | 08:38 AM
AL5461's Avatar
W221 S500
Long Island, NY
I occasionally end up in NYC but no trips lined up over the next few weeks. Had you been in Cincinnati I would have bought my laptop with me...
Old Sep 19, 2025 | 07:23 PM
Much appreciated man!
Old Sep 20, 2025 | 10:42 AM
justchangeoil63's Avatar
2019 Mercedes S560
Looks like you need to get the sunroof re calibrated if it does fully close manually. You can do it yourself in the car but that does not always work.
Id goto a shop or the dealer (yikes) and have them re code the sunroof. My car did this randomly one day as well. The re coding fixed it.
Good luck!
Old Sep 20, 2025 | 11:41 AM
Good luck!
Good to know man, thank you.
I actually did try to recalibrate it myself by holding the button in tilt-up position for 10 seconds, etc but nothing happened. I also ran it through some calibration process on my Autel scanner, where it did go through its process, but did not resolve the sinking issue.
I’d imagine with Xentry it is different and will resolve it.
Old Sep 21, 2025 | 05:37 PM
2019 Mercedes S560
Hmm weird, that makes me think there is something mechanically wrong with the sunroof. Def get it checked out. I don't know what system my mechanic used to recode it but it certainly worked.
Good luck!
