Radiator drain plug petcock leaks
Old Nov 4, 2025 | 09:50 AM
Jaap's Avatar
2006 W221 S500L M273
How wonderful.
My car has the black coolant drain plug (as opposed to a red one) and it does not stop draining when i close it :'(
I think it may be partnumber A0009970733 but that does not show as compatible with w221 and i cannot find the part in the stupid (official) EPC.
Can this part be replaced or do i need to replace the whole radiator?
Old Nov 4, 2025 | 10:43 AM
Arrie's Avatar
Originally Posted by Jaap
How wonderful.
For my 2010 E-Class I bought the drain plug from a Dodge dealer. At the time I read in these forums for E-class that MB does not sell just the plug, and you need to buy the whole radiator to get one.
Dodge (Chrysler) plug is from the Daimler-Chrysler years and is exact match and fits perfectly.
I think it is the same plug in our S-class.
Old Nov 4, 2025 | 12:35 PM
Jaap's Avatar
Were you able to just pull the old one out and put the Dodge-plug in?
Old Nov 4, 2025 | 01:15 PM
Arrie's Avatar
Yes.
But you don't just pull it out. Turn 90 degrees, pull about 1/4", turn another 90 degrees and then pull it out.
It is the same plug for the part that mounts in and seals it. The flat handle part was a little longer if I remember correctly, which does not make any difference how the plug works.
It also was a bit cheaper at around $15 compared to few hundred dollares of the new radiator + installation.
Old Nov 4, 2025 | 04:09 PM
TimC300's Avatar
Maybe the o-ring is worn/deformed or the plastic is chewed up. I would pull the drain plug out and see what it looks like.
I have an old craftsman floor jack that was leaking fluid at the plunger so took it apart to measure the o-ring to buy a new one and after i put it back it stopped leaking. While i had the o-ring off the plunger I coated it with silicone grease.
Not saying put it back and leave it. Remove it to measure then order a new plug.
My M272 radiator has that type of drain plug and the part# is 0009970224. Ive also come across 0009970024.
Old Nov 6, 2025 | 08:05 AM
Jaap's Avatar
It worked. Thank you guys for the help.
I got the A0009970733 from the Merc dealer and was able to pull the old one out (which was not easy, pulling and twisting it, stupid ABC line in the way)
and putting the new one in (that was easier, i put a little silicone spray on the rubber o-ring).
Old Nov 6, 2025 | 04:25 PM
TimC300's Avatar
What does the old part look like, any signs of why it was leaking fluid?
Old Nov 7, 2025 | 11:09 AM
Jaap's Avatar
Yeah i had twisted it too far to the left and to the right.
Never twist it more than 90° or you will screw it up.
Old Nov 7, 2025 | 10:55 PM
Arrie's Avatar
Yeah,
See post #4.
