Ignition key wont even turn
Old Mar 18, 2026 | 07:25 AM
NoBrakes's Avatar
S-class W221
Unhappy Ignition key wont even turn
I didnt drive my car all winter, its spring now and all of the electronics are off, i could barely even open the car door, when i got inside to start the car, but the key didnt even turn, everything was stiff, the steering locked, when i put the key in the ignition, nothing light up, I dont know if this has ever happened to anyone else, I dont know which battery is dead, the one in the boot or the one at the engine bay area.
Please advise
Old Mar 18, 2026 | 07:40 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
You need to charge your batteries. The first suspect (for the key) is the smaller aux battery. For giggles - you can hook some jumper cables to another (running) car and see if the voltage enables the key. If you can then start the car - maybe just maybe the alternator will charge the system up.
Old Mar 18, 2026 | 09:23 AM
streborx's Avatar
Top Answer: 1
G550
When you store your car for any prolonged period, you need to connect a battery maintainer to it. Don't believe the willie-nillies who insist you'll overcharge your battery and destroy it. Likely you've destroyed your batteries by sucking every last electron out of them.
Old Mar 18, 2026 | 09:42 AM
AL5461's Avatar
W221 S500
Please advise
Both probably.
When the voltage of the consumer battery in the trunk drops below a threshold it puts the car into hibernation. This happens after 2 or 3 days. Then you have to unlock the car with the key blade, and it's a bit of a pig, but when you insert the fob and turn it the starter battery has enough juice to turn on the instruments and start the car. Then after a decent period running, everything gradually comes back... The essentials instantly and the toys later.
The fact you have nothing says both batteries are dead. If they're in warranty return them otherwise budget for new ones.
Old Mar 18, 2026 | 09:44 AM
AL5461's Avatar
W221 S500
To quote a wise man... Wish in one hand and sh*t in the other and see which fills up first.
You might get lucky, but...
Old Mar 18, 2026 | 10:42 AM
JohnLane's Avatar
222 S-65
OP if both batteries are (and have been for months) dead they are not returning to life with a charge.
Do also verify that the fob battery is alive.
Fresh batteries and a few prayers she may just light up and not greet you with a plethora of undervoltage codes.
A battery maintainer is the solution in the future. Mercedes offers one.
Old Mar 18, 2026 | 11:18 AM
AL5461's Avatar
W221 S500
There will be under voltage codes in every single module. Of that you can be absolutely certain 😉
Old Mar 18, 2026 | 11:48 AM
JohnLane's Avatar
222 S-65
Hopefully it doesn't make for a christmas tree of warnings. Sometimes they wake up; shake it off and make you program the clock and memory settings without drama.
OP will see.
Old Mar 18, 2026 | 02:21 PM
Senecat's Avatar
1983 Nissan Shltbox
to warranty-out batteries you destroyed would be unethical. why should i have to pay for someone else's immorality?
bro, you have no anything because you killed your batteries. you don't need us to tell you that, do you?
Old Mar 18, 2026 | 02:35 PM
AL5461's Avatar
W221 S500
Why put a 3/4/5 year warranty on a battery if it doesn't last that long? That's the definition of a warranty... To replace something if it fails before it should. Doesn't matter if it's a loaf of bread that goes mouldy before the expiration date or a battery.
Old Mar 18, 2026 | 03:10 PM
Senecat's Avatar
1983 Nissan Shltbox
He killed those batteries by not caring for them properly.
You won't win this one, bro.
Old Mar 18, 2026 | 03:25 PM
AL5461's Avatar
W221 S500
It's not a competition, if they're under warranty, they're fair game, if they're not, it's a $600 lesson.
First thing I had to do to mine was replace both batteries... Previous owner had fitted 2 MB AGM batteries 6 months prior but the history was lost, so no comeback for me.
One of the Bosch batteries I fitted to replace the MB ones failed 18 months into its 4 year guarantee. Went straight back and they added the balance to the replacement.
Old Mar 18, 2026 | 04:00 PM
If that were my battery it was dead and under warranty? Sure as can be I am going to warranty that battery.
Old Mar 18, 2026 | 05:14 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
I'm with @Senecat on this one. Why should a manufacturer pay for something that was abused? If the battery was maintained proplerly it wouldn't have failed, probably. But left on a constant drain with no charge for months is not how a regular car battery is supposed to be used. These batteries re not deep-cycle batteries. Man up and pay the piper for your mistake. As a former importer and distributor, I got fed up with people abusing my products and saying there's a manufacturing defect.
Senecat's Avatar
1983 Nissan Shltbox
Warranty does not cover abuse/misuse.
Old Mar 18, 2026 | 06:40 PM
JohnLane's Avatar
222 S-65
Guys... Do we really need to pile on like this? OP hasn't been back.
Old Apr 19, 2026 | 02:32 PM
NoBrakes's Avatar
S-class W221
I hate Mercedes!! i will just leave the car to rot there, **** it !
Old Apr 19, 2026 | 02:45 PM
Senecat's Avatar
1983 Nissan Shltbox
Lol
Old Apr 19, 2026 | 08:59 PM
AL5461's Avatar
W221 S500
Guess you haven't changed the batteries then...?
