Door dosent close ?!!!
Any codes in the door module? Soft close is one of the luxuries that goes with a low battery voltage. Start there.
Does it work on the other doors?
You could try manually latching the door whilst it's open... Use a pen to roll the latch to the second stop, then release it with the inside handle and try closing it as a reset from the manual unlocking from your previous issue.
Either way, a body shop can sort it in short order.
there was an early TIPS doc about it and either handle replacement and or cut down part of the handle to open up its clearance
my rears have done it for years as I seldom operate them - crud builds up over winter and this is often enough to cause the issue - clean with a tooth brush and lube and it still pays up
wd40 tends to swell seals so doesn't help
ACF 50 also was never quite the right thing
Silicon lube doesn't seem to work either
doesn't matter how much you clean or how liberally you apply lube - best cure is to use the car
my drivers door has just spent 2 weeks doing it - cleaned sprayed wd40 as it was lying around - helped a bit - but its exercise that's the real solution
